Smog Friendly Power
Sadly the only Smog legal turbo kit around for Cali would be STS kit.Heads are legal, cam just has to be a certain size. There is info in here if you search around specifically in this section.
I'm pretty sure 228/228 cam is the absolute biggest you can go and still pass smog.
You can have a shop port and polish some 243's and put you up there as well.
From my experience, too big of a cam, and altering the exhaust is the biggest way of failing smog. You can do a forged bottom end, a 228 cam, ported and polished heads, intake and throttle body and make decent power. If you dont mind swapping exhaust every 2 years you could do long tubes with gutted or regular cats.
Then theres always the P1, which is smog legal or even a nitrous shot which is easy enough to uninstall every 2 years.
Before doing any of this, i would do a 3600 stall, that will make your car feel like a totally different car instantly. I picked up half a second on a bolt on/free modded 98 camaro with a pi 3200.
