Western Members CA, AZ, NV, UT, CO, NM, HI
salvege title options
Old Dec 7, 2012 | 07:54 PM
t79z28's Avatar
Default salvege title options
Well I just had the car for about a month got rear ended and Honda pilot sat on it...long story short the body damage out weighs the cars value...does this give me more options to drop a 6.0l in it and be legal if the title becomes a salvage? I think all I would have to do is keep the smog equipment that the 6.0 came with and get a BAR inspection...ya I am in cali...btw first post so I am pretty proud of myself...was hoping the first post would be showing off the 6.0 swap w out this crashing business but whatcha gunna do...
Old Dec 7, 2012 | 11:24 PM
Jeremy 92 RS's Avatar
Salvage title/body damage is not gonna help you with anything smog/emissions related.
And putting a 6.0 in place of the 5.7 block is no big deal as long as all of your smog equipment is in place... bite your lip through out the smog test, the smog tech wouldnt be able to tell the difference.
Old Dec 8, 2012 | 01:12 AM
t79z28's Avatar
thanks for the reply, I thought it might help them assume I yanked a gutted car from a junk yard...it is a base v6 though So I think at a minimum I am looking at having a new vin issued to reflect the v8? and for sure mum is the word on that one
Old Dec 8, 2012 | 09:28 AM
As we all know, A V8 LS1 engine was a factory option for Camaro/Firebird. Smog techs could care less if it started as a V6, and they dont care about sub models such as Z28, Trans Am, SS, etc. For example, if you had a 98 base model V6 Camaro and then swap a 98 LS1 motor in it, as long as all of the 98 V8 emissions equipment is present, hooked up and working you could bring it into any smog station and smog it as a normal V8 car without any issues.
Old Dec 8, 2012 | 10:28 AM
t79z28's Avatar
Cool
that is great, you just saved me a lot of heart ache, I am about half way ready to start the swap Ill just save the cool guy bolt on stuff till after it goes threw smog Unless I miss understood what I read online as long as the donor engine is not out of 1/2 ton or heavier truck its ok? The donor engine and harness are out of a 02 avalanche? Either way its gonna happen I just want it to be as painless as possible on the legal side of the swap
Old Dec 8, 2012 | 10:45 AM
chevymec's Avatar
Are you sure its a 6.0 and not a 5.3 on the Avalanche?
KILLER-LS1's Avatar
You are going to need a harness & computer from a V8 Camaro if you want it to work. The avalanche comp & harness won't connect with any of your gauges or smog equip.
Old Dec 8, 2012 | 11:07 AM
t79z28's Avatar
Ill recheck my sources but I am sure it is a 6.0 might be off on the vehicle year? I am having a shop do all the trouble shooting. So all I need is the engine? and the electronics have to come from a ls1? Thanks for you help...I am fairly dumb w fuel injection obdII and whatnot
Old Dec 8, 2012 | 11:30 AM
Not many Avalanches were 6.0. So you may want to double check. Just remember when you smog, dont say its a 5.3 or 6.0. Just let them do their thing.
Old Dec 8, 2012 | 11:48 AM
t79z28's Avatar
Thats the plan... the shop is closed on the weekend at least I get a few days to over think this. well I guess my weekend is going to be filled with reading, gatta love this car stuff. Thanks for all your help guys monday Ill pop over and see them and snag some pics
Old Dec 8, 2012 | 06:18 PM
slogoat's Avatar
6.0 wasn't an option until 2007, if the motor is out of an 02 it's most likely a 5.3. Keep us posted on how the build goes
Old Dec 8, 2012 | 08:45 PM
True. The few 2500 Avalanches you see are 8.1's prior to 07.
So if the motor is really a 6.0, its probably out of a pickup instead.
Old Dec 8, 2012 | 10:42 PM
t79z28's Avatar
Would it still be a ls3 engine? despite what it came out of, if in fact it is the 6.0? Long gone are the days of just a 350 short block lol
Old Dec 9, 2012 | 01:36 AM
LS3's are 6.2L.
Old Dec 10, 2012 | 03:06 AM
t79z28's Avatar
Damn my lack of knowledge!! I am going to quit worrying about it and let the shop do there thing, they have been pretty great in dealing w me so far, as far as the car goes I have the F41 suspension and 3.42 rear w posi, that should be able to support the new block just fine I assume?
Old Dec 10, 2012 | 11:08 AM
It will get you by fine for now. 3.42s are a great gear for an auto, but if you have a manual transmission the 3.42s are what come stock. What are your plans for the car? Cruiser? Corner carver? Drag racer?
Old Dec 15, 2012 | 10:36 PM
t79z28's Avatar
sorry been busy, I did confirm that its a 6.0 so I am happy. I want reliability over all, but it will see heavy dd duty so carving up some corners is what I am going for. I already had some sub frame connecters hooked up, slapped a new harwood 2.5 cowl on it looks good I do owe it some paint though. and ya it is a auto, and I plan on keeping it that way
