Western Members CA, AZ, NV, UT, CO, NM, HI
Smog law AZ ?
Old Jul 20, 2005 | 02:06 PM
99SSragtop's Avatar
Default Smog law AZ ?
Yes, No ?
Old Jul 24, 2005 | 02:29 PM
sixpackmotorsports's Avatar
ran on a dyno last i heard, very similar to california's laws.
Old Jul 24, 2005 | 02:51 PM
Lithium's Avatar
SSU's Drunk Typing Whore
I think that it depends where you live in AZ.
Old Jul 27, 2005 | 03:02 PM
SlpLS1's Avatar
no.. all they do is hook it up to the comp. just make sure u have no codes.. make sure everything is erased
Old Jul 30, 2005 | 01:26 AM
radio626active's Avatar
depends on where you live is right, lots of counties have zero inspections........like mine!
Old Jul 30, 2005 | 10:48 AM
calys968's Avatar
Where do you live? I used to live in Cochise County
Old Jul 30, 2005 | 10:44 PM
Cornfed's Avatar
Tucson and Phoenix are the same they hook you up and just hope they dont look around. No codes no problem. You cant just remove the codes and roll in it wont work.
Old Aug 1, 2005 | 05:23 AM
sdbrown84's Avatar
I had my codes removed by a custom tune by RWTD. Will this cover me in Maricopa county?
Old Aug 3, 2005 | 11:14 AM
2000Blackout's Avatar
Wanna bet? I went thru in April,SES came on a few days before cleared it drove about two miles to the emissions station and passed!
Old Aug 9, 2005 | 02:34 PM
2001CamaroGuy's Avatar
........but as long as you turn the code OFF (so the computer does not even LOOK for the part/code...ie: rear O2s) you will go right through.....
96 and later (I think).......all OBD2 cars are just OBD2 scan...they DO NOT even look under the hood/car
pre-OBD2 (or if you don't pass OBD2) are still rollers smog test........
Old Aug 9, 2005 | 04:09 PM
Freaklt1's Avatar
Removing the codes will work. I removed my rear 02's and egr and deleted the codes. It was detected, but they allow you to have 2 items that are inoperative.
8GTOKLR's Avatar
65 and newer gets smogged every year
Old Aug 9, 2005 | 04:27 PM
Freaklt1's Avatar
Every 2 years
Old Aug 9, 2005 | 07:32 PM
incorrect......67 and newer......
Old Aug 10, 2005 | 01:02 AM
schultzsj's Avatar
Much of AZ does not have smog testing but the Phoenix metro area tests every two years after the car is five years old. They just switched from sniffer to OBD-II testing (96? & newer). My car would pass the sniffer but I have the rear O2's deleted and I went right through.
Steve
Old Aug 10, 2005 | 02:28 AM
sdbrown84's Avatar
I believe it is 1967, lucky very first gen guys... But I beleive I turned mine off so I hope to be alright. Anyone not pass when they supposibly had them turned off in their PCM?
