Western Members CA, AZ, NV, UT, CO, NM, HI
Clicking noice when accelerating hard and turning.
Old Dec 12, 2007 | 01:37 AM
chevystyle's Avatar
Default Clicking noice when accelerating hard and turning.
Well, I finally bought a 1998 SS, but got a few questions. Under hard acceleration and accelerating outta turns, there's clicking noises or knocking noises coming from the rear end. I was just told that the car has posi. The car dosen't have traction control. Is this true that the noise is normal because of the posi??
I'll send pics and info on the car later on. Thanks.
Old Dec 12, 2007 | 08:11 AM
eddielb's Avatar
no, it should not make any of those noises, get your rear checked before it goes BOOM like derek's did
mine was whisper quiet when I first got it, then I put in 4.10 gears and it whistles lightly at freeway speeds and quiet at turns etc... need to get mine checked osmetime too...
Old Dec 12, 2007 | 09:37 AM
180ls1's Avatar
check to see if it has oil in it.
Old Dec 12, 2007 | 10:41 AM
GinoLS1's Avatar
Check your wheel bearings and seals
Old Dec 12, 2007 | 11:08 AM
LS1BLKSS's Avatar
Banned Village Idiot
... mines does the same thing when i really step on it and always on turns... it never done that before... it started when i got my Headers installed with the Y pipe... i was told it could be the y pipe??? i have a cut out and when its open you can only hear it on turns but when its closed you hear it when i step on it and turns!... do you have headers???
Old Dec 12, 2007 | 11:41 AM
Black02LS1's Avatar
I dont have that problem.
Old Dec 13, 2007 | 12:30 AM
chevystyle's Avatar
Nope. No headers. The person that I bought it from did put 4.10 gears in it and replaced the cats with high flows with new piping all the way back with a flowmaster. I do plan on getting the rear end serviced around Christmas time. And with the wheel bearings and seals, how do I go about checking on that?
Old Dec 13, 2007 | 12:47 AM
dred500's Avatar
my buddys 2000 ss does that clicking noice when he stops or goes
dosnt matter what speed it is
it still does it
Old Dec 13, 2007 | 01:21 AM
chevystyle's Avatar
How do I go about fixing that clicking noise?
Old Dec 13, 2007 | 02:09 AM
wsSIKK's Avatar
mine did that, and progressively got worse, and it ended up being my spider gears. had to replace my diff
Old Dec 13, 2007 | 02:49 AM
cam's Avatar
cam
If you still have a Torsen carrier those are the sounds they make before they go boom. Its the side gears that loose teeth and make the clunk/popping noise. Eventually the car will no longer move so your going to want to look into this sooner rather than later
Old Dec 13, 2007 | 03:13 AM
Revelation Z28's Avatar
he has an auburn. 98's came with them.
Old Dec 13, 2007 | 09:44 AM
GinoLS1's Avatar
You'll have to take it to a shop and tell them to check those for you......
Old Dec 13, 2007 | 11:31 AM
Jawsgear's Avatar
You can pull ther rear cover and check for any metal debris in the oil or on the magnet. That would be your first indicator of a problem. Let me know if you need any parts.
Jeff
Old Dec 13, 2007 | 11:56 AM
01Z28M6's Avatar
I have a 95 that came with an Auburn but there's a torsen in it now. His gears were changed by the previous owner and maybe the differential at the same time. He needs to have a look behind the cover plate soon.
