Western Members CA, AZ, NV, UT, CO, NM, HI
smogable heads and cam
Old Mar 22, 2008 | 10:08 PM
180ls1's Avatar
Originally Posted by hlaalu
it would show the car is running lean tho right? so that would pop up a ses light. what if u just clear all the codes right before you let the guy take your car?
i dont know it never threw a code on my buddies jeep but i know our cars are a lot different
Old Mar 22, 2008 | 10:32 PM
hlaalu's Avatar
hmmm anyone know?
Old Mar 22, 2008 | 10:40 PM
180ls1's Avatar
hmmm anyone know?
i know the molecules are close to twice the size of of gas so you could do your percents from there. maybe if you did the timing ticker mod it would richen it up if you only used a smaller amount of ethanol and it would balance out.
this mod when you smog it on a warm day:
http://www.installuniversity.com/ins...ricker_mod.htm
Old Mar 23, 2008 | 03:17 AM
hlaalu's Avatar
what is the timing ticker mod? i need to do something to richen up my system.. i get the too lean codes every other day =(
Old Mar 23, 2008 | 11:25 AM
HellaciousA's Avatar
Originally Posted by Soul TKR
Ryne put a 224/224 cam in mine with AFR heads.... I figure if I had cats and mufflers i'd pass smog... I know the AFR's are carb legal and with his tune on the cam, it should pass...
put down 446/416
What other mods did it take to put down those numbers? FAST? longtubes? just curious as Im about to start stockpiling parts for a h/c swap.
Old Mar 23, 2008 | 01:47 PM
180ls1's Avatar
haha i linked it in my post but i will link it again if you cant see it i will pm it to you. It costs like $1 and makes your car think it is 57 degrees outside.
Old Mar 23, 2008 | 01:52 PM
hlaalu's Avatar
omg lol i think i thought it was your sig or something. haha thanks dude!
Old Mar 23, 2008 | 04:49 PM
Dissident's Avatar
My last car was a 02 ZO6 and it was a H/C car. I had MTI Stage 2e heads and a X1 cam, ported tb, tpis long tube headers, Borla exhaust and 31lbs injectors. Although a picky smog tester might not let the visual pass, I found most didn't care as long as it passed the sniffer, which it did with flying colors. Infact, in some cases the results were a little better than stock. Btw, the car put down 430 rwhp.
Almost as important as the parts you choose, will be who you have dial the car in. A lot of tuners were tune for power under WOT but don't do a lot for the mid, low, and idle. Make sure you have a tuner that knows you want to be able to pass the sniffer.
Old Mar 23, 2008 | 04:58 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
i just had a 383 camaro with 227-232 112+2 cam pass the sniffer with american racing long tubes and cats........ but on average in a stock cube car 224-228 114+2 is the biggest that will pass reliably, as far as heads any of them to be honest as long as its tuned correctly it will pass. of course this may very on the smog technician if he will over look visual inspection.
Old Mar 23, 2008 | 06:11 PM
hlaalu's Avatar
geez thats incredible. i remember i was freaking out about passing when i just had a smooth lid and bellow =P
Old Mar 24, 2008 | 10:42 AM
ZMONSTER!'s Avatar
well potentially, with a smog passing tune how much power is the 224-228 114+2 cam capable of making? Also what will it sound like? Keep in mind my exahust will be nearly totally stock, only change will probably be an LM2 catback.
Old Mar 24, 2008 | 10:51 AM
  #32
Ryne @ CMS's Avatar
LS1TECH Sponsor
well a smog passing tune really doesnt exist or isnt needed, you just need to tune the car and make sure all the fuel trims are in line. as far as sound and power it will sound nice a slight lope, and power wise through stock manifolds you are looking at around 360-380 wheel conservatively
Old Mar 24, 2008 | 10:53 AM
  #33
ZMONSTER!'s Avatar
oh **** forgot to add Ill be going with AFR 205's from texas speed, their "mongoose" Pkg
Old Mar 24, 2008 | 10:55 AM
  #34
Ryne @ CMS's Avatar
LS1TECH Sponsor
must likely around 400 wheel then, the manifolds are really going to hold you back
Old Mar 24, 2008 | 10:56 AM
  #35
ZMONSTER!'s Avatar
ya, I know. damn visual inspection!
Old Mar 28, 2008 | 10:41 AM
  #36
ZMONSTER!'s Avatar
Ok just talked to Texas Speed(Great service! Answered alot of vauge questions well!) And This is the Pkg that was recomended to me;
PRC stg 2.5 5.3L heads
TS 224R cam on 114LSA(224/224 .581 lift 114LSA)
So, with stock manifolds(I live in california thats why!) Im hoping this will put me somewhere around 380-400rwhp on a smogable tune. What do yall think?
Old Mar 28, 2008 | 11:43 AM
  #37
ZMONSTER!'s Avatar
Old Mar 28, 2008 | 12:24 PM
  #38
180ls1's Avatar
seems like it will rip but i have heard the cheatr cam is designed for stock manifolds and will get you the best gain. as far as heads i think it depends on how much money you have.
Old Mar 28, 2008 | 12:36 PM
  #39
ZMONSTER!'s Avatar
ya Ive heard similar, and Id like to speak to someone who has run a cheater cam before. Id still like to know what this combo would make. The seller said approximatly 75-85rwhp gain, which would put me pretty close to my origional goals. Also, dont know if Im being a stupid newb here, but the dyno graph of the cheater cam looks like it sucks! dosent develop max power until redline...no power "under the curve" as it were.
Old Mar 28, 2008 | 12:46 PM
  #40
ZMONSTER!'s Avatar
Cheater is 214/230 .601/.575 117LSA....even come close to passing emissions?
