SS LED = Non Functional Brake Lights??
Hey everyone,
I was wondering if wiring in an SS LED spoiler light would cause my other two brake lights to not work. When I press the brake pedal, only the spoiler light turns on. I've searched already and did not find a similar problem. Thanks.
Carlos
Carlos
im getting an ss spoiler for my 02 v6 and im just wondering what kind of resistor or relay do i need? also i just splice to connect the 2 wires coming from the brake light?
I am not familiar with the swap, but if you are blowing fuses, you need to find out what is causing a big draw. Did you follow a write-up while doing the swap? If it's not an installation-related issue, than as mentioned before, check for grounded, damaged, crossed, or frayed wires. Good luck with it.
