Western Members CA, AZ, NV, UT, CO, NM, HI
This is what went down......
Old Jul 26, 2008 | 04:53 PM
'00Z28's Avatar
So I went today to the smog station. I wound up putting in the Guaranteed to pass emissions formula. Everywhere I happened to check was out of stock with sea foam so I said screw it and tried it out. I basically had to wait a bit after putting it in. It recomends that you drive through an entire tank then refill and go straight to the emissions test. So after filling up today I drove it about twenty minutes fairly hard on my way to test it. The emissions still wound up failing, and it was even worse. My HC doubled. The CO doubled and the NO tripled. A week ago I barely missed on HC and now it was complete **** on all read outs.
Any thoughts. I have no idea what else I can do. I can't believe that the cats all of the sudden took a **** that bad in exactly one week. The difference between last week and this week is that my cats were way hotter this time from diving the **** out of it, and I put in the G2P which is pretty much bullshit from what my read outs are.
Old Jul 27, 2008 | 02:23 PM
ae13291's Avatar
did u do seafoam? i also heard if u can get ethonal i hear u can sometimes pass with no cats since it burns so clean
Old Jul 27, 2008 | 03:07 PM
1SLO6's Avatar
HC's equals rich running condition..... i believe... get the cats hott and then go for the smog....
Old Jul 27, 2008 | 03:23 PM
99Bluz28's Avatar
Thumbs up
Walmart also carries Seafoam now! If you put it in your gas it's 1oz per gallon of gas.
Old Jul 27, 2008 | 05:22 PM
intense3123's Avatar
Seafoam wont' do anything for HCs.
HCs means hydrocarbons = unburnt fuel.
How are your plugs?
Old Jul 27, 2008 | 05:53 PM
hlaalu's Avatar
there isnt a way to just program your car so it puts in less fuel? would that allow for a pass?
Old Jul 27, 2008 | 09:30 PM
'00Z28's Avatar
I got those cats pretty damn hot when I went down for the check. Today I just replaced all the spark plugs. I have a feeling that that also might have a little to do with it not burning off the fuel. I got a new air filter as well, the oneI just replaced was dirty as **** and the last time I changed the spark plugs was about 20,000 miles ago. There was a pretty potent furel smell when I changed them out, not too sure if you normally smell that when doing it. I don't remember it smelling like that last time. The old plugs were pretty dirty. Nothing too crazy though. I also have a feeling that my EGR valve might be a little crapped up with carbon build up too.
It's just weird that in one week it got so bad on the sniffer. I was off by just a bit on the HC last week, then now all the read outs were doubled and the NO was trippled.
A side note... after the tune up I no longer have the infamouse ticking sound coming from my engine anymore.
Old Jul 27, 2008 | 09:46 PM
hlaalu's Avatar
maybe you just got a shitty batch of fuel?
Old Jul 27, 2008 | 09:51 PM
'00Z28's Avatar
Possibly.
I know this could potentially be a bad question, but oh well: What fuel do you guys use normaly? I fill up with 76 because there no techron or anything like that in it... as far as I know. Sorry if this is a dumb *** question, but whatever could help I'll take.
Old Jul 27, 2008 | 10:02 PM
noriceinside's Avatar
well you solved your problem. clogged air filter and old spark plugs would be the first things i'd do if i had high hydrocarbons. you should pass fine now. seafoam or some kinda of decarb would help your chances, but i think youve got it in the bag.
Old Jul 27, 2008 | 10:19 PM
'00Z28's Avatar
Lets hope so. It's just throwin me off how it got so bad in one week. Just kinda weird. Maybe that Guaranteed to pass formula still needed to clear out of my gas tank too.
The only difference was that going through my car (went through an entire tank then refilled) and my cats were way hotter than they were the first time.
Just ****** weird......
Old Jul 28, 2008 | 04:28 PM
  #32
ae13291's Avatar
Originally Posted by '00Z28
Possibly.
why dont u like techron? its all the same **** but i prefer chevron and mobil, but never will i fill Arco
Old Jul 28, 2008 | 10:44 PM
  #33
I fill up with Arco every single tank and have never had problems. And I had the car smogged last month, so it is possible to pass with arco gas
Old Jul 28, 2008 | 10:46 PM
  #34
Raptor_WS6's Avatar
i only use 76 and mobil, i stay away from arco
Old Jul 31, 2008 | 02:46 AM
  #35
Bigdeezs's Avatar
Also bad plug wires and low compression or dead cylinder (misfires) will also cause high HCs.
If the car was running rich you would see high COs.
Have you tried again yet? I'm curious to see if the plugs did the trick.
Old Jul 31, 2008 | 03:03 PM
  #36
tomz28's Avatar
lean it out make a big vac leak hahahahah j/k mybe a retune?
Old Jul 31, 2008 | 04:22 PM
  #37
'00Z28's Avatar
FUUUUUUUUUUUUUCCCCCCCKKKKKKKK!!!!!!!!!!!!!
Failed again. New plugs, wires, air filter, and egr valve. Passed CO and NO at 25 mph, but failed everything else.
So...............
Anyone know someone who needs $200 in Santa Clara?
Old Jul 31, 2008 | 08:37 PM
  #38
if you had a dead cylinder not only would you notice it running shitty but it should also set a code for misfire and thus fail the computer check as well.
it sucks, if you were closer i'd be more than happy to look at it with you.
Old Jul 31, 2008 | 08:44 PM
  #39
how is your evap? your purge solenoid isnt leaking is it? if it isnt sealing your engine could be sucking fuel vapors through it.
Old Jul 31, 2008 | 09:42 PM
  #40
With all that new **** you put in, I can only guess that your TS y-pipe cats are too far away from the combustion chamber and too cool by that point to do much good. Time for a hookup.
