HAS ANYONE DONE THIS? trap door
#44
for anybody interested in doing this just remember that the 93-98 f bodies have the fuel pump module located differently on the tank...
the reason being 93-98 fbodies had the charcoal canister remote mounted from the fuel tank, where was the 99+ fbodies have the charcoal canister mounted on the tank itself...
on the 93-98 fbodies the module is located farther towards the front of the car...when making the cut its not a bad idea to make it in a small L shape towards the driver side of the vehicle...this will make it easier for you to reach the quick disconnects...
on the 99+ fbodies the module is located farther towards the rear of the vehicle..
if someone can find me a pic of the axle tunnel from the interior of the vehicle i can draw out where the cuts need to be made...
#52
How in the heck does it take you more time to simply pull out two pieces of plastic and lift up a carpet?
The first time you do this mod it MIGHT take a whole half an hour since you're cutting the hole. One hour if you go REALLY slow because you are scared.
After that first time it should literally take you ONE MINUTE to access your fuel pump...
I'll race you to get to your pump for $100 if you want![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
#56
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
actually that be a good idea for a track car, in case the pump took a **** on the track, you can damn near be staging and swap pumps hahahaha
also he didnt say if he was putting in a race pump or just replacing the stock one cause it went out
#59
hey all im saying is to change the fuel pump the proper way it is preety simple, i wouldnt be too happy if i took my car to a dealer or somewhere and they cut a chunk of floorpan out because it would be "easier" when i have to replace the pump again. On the 97 that would be a good size hole, twice as big as the one above just to get it out. My friend did it and its still a bitch on his 98 and the car still smells like gas inside with a panel. I wouldnt know why anyone would be changing their fuel pump that much. A pump should last long enough to not make it a every weekend project. And of course i know why people change their pumps other than to fix them. So does that mean people are going to start cutting out access panels in their inner fenders to make spark plug access easier? how bout a access panel on top of the tunnel to get to the top of the bellhousing?![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
Sorry just my $.02, im not trying to argue just giving him options, anybody can do what they want to their cars, its just advice
97 is same style as 98 and my hole isn't too big. If you're friend's car smells like gas he has a much bigger problem than the access hole...
THINK ABOUT IT that means his gas TANK isn't sealed properly. An access hole doesn't allow fumes in because THERE SHOULDN'T BE ANY FUMES COMING OUT OF A SEALED GAS TANK.
Sorry but that comment (about friend's car smelling like gas) makes it sound like your just pulling ***** out of your @ss to make your opinion more valid and what you're pulling out makes no sense to anyone with half a brain.
#60
Again, I say the "proper" way is to have a damn access panel. Your analogies are ridiculous. I guess you'd be against adding a drain plug to your tranny pan as well since the "proper" way to change fluid on our penny pinched designed cars is to always drop the pan...
