HAS ANYONE DONE THIS? trap door
#61
Again, I say the "proper" way is to have a damn access panel. Your analogies are ridiculous. I guess you'd be against adding a drain plug to your tranny pan as well since the "proper" way to change fluid on our penny pinched designed cars is to always drop the pan...
97 is same style as 98 and my hole isn't too big. If you're friend's car smells like gas he has a much bigger problem than the access hole...
THINK ABOUT IT that means his gas TANK isn't sealed properly. An access hole doesn't allow fumes in because THERE SHOULDN'T BE ANY FUMES COMING OUT OF A SEALED GAS TANK.
Sorry but that comment (about friend's car smelling like gas) makes it sound like your just pulling ***** out of your @ss to make your opinion more valid and what you're pulling out makes no sense to anyone with half a brain.
+1 Never smelt anything on any of the installs. And if you think thats where its coming from use a little silicone... To be honest, what they are probably smelling is gas that they spilt on the carpet (or inside the car)... not fumes from the tank. Fumes from the tank would mean the system isnt sealed, which would cause the car to run really bad. Try driving w/ your gas cap off, it would be similar.
#67
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#70
no **** of course his "panel" isnt sealed properly, and he probably spilt gas everywhere, but **** im sorry if i was just suggesting how to do the fuel pump per book, you dont have to get your panties in a bunch and put me on blast. Let him decide how he wants to do it and if he puts in a stock or high performance one, o n my trans doesnt have a pan
, and how does "penny pinched" relate to a camaro having or not having a trans drain plug, name all the chevys youve seen that had, so does that mean all the vehicles that dont have a access panel and a drain plug on the trans is penny pinched? But ya sure my analogies are ridiculous i guess ill go buy a ford
#75
im all about taking out the tank my self. it does not take more than 30 min for the tank. i dont drop the rearend or anything crazy like that. but i dont plan on working on my fuel pumps all the time like some of you. im not in to cutting up my car any more than i have to LOL. just my 2 cents
#78
#79
wow you mean theres someone else that can do exactly what ive done in the same time?!?!?!?!?!, o i dont drop the reared all the way either, i just disconnect the shocks. +1 for not doing this monthly
. Cant believe the people argueing with me. And the threadstarter just had a dd, that he wasnt doing anything that required a higher flow pump.
#80
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
I did mine with a full tank and it was easy and came out great!
Convertible was harder than it would be with a non but i would still recommend going this route.
http://camaroforums.com/forum/showthread.php?t=38304
Hope this helps anyone!
