Western Members CA, AZ, NV, UT, CO, NM, HI
overheating???
Old Sep 24, 2008 | 06:52 PM
1sick68's Avatar
Default overheating???
need some help on this, my car gave me a scare today. usually the temp is in the range of 195-200, and today it passed it all the way to 210, is there a issue or am i just going crazy. it has plenty of coolant and a new water pump, radiator new also. info please thanks.........
Old Sep 24, 2008 | 07:01 PM
camarojunky74's Avatar
info on your car please
Old Sep 24, 2008 | 07:06 PM
Wicked_muscle's Avatar
When was the last time you changed your thermostat?
Old Sep 24, 2008 | 07:14 PM
1sick68's Avatar
well the engine is not more then a month old, it runs great its just that it pushed that 210, the engine is stock no mods, what do you think.........
Almostryan3's Avatar
First off we need some info on the situation. Such as were you sitting in traffic were you racing what? Second, like camarojunky said we need more info on the car. How low was it overheating did you shut it off? Did it just come down what? Were missing a lot of info here before we start pointing our fingers at any parts, for all we know a bag could have got sucked up there and blocked off air.
Old Sep 24, 2008 | 07:15 PM
Refer to my post, also what motor in what kind of car? Who built it? Was it fine up until now?
Old Sep 24, 2008 | 07:17 PM
1sick68's Avatar
when i got the new engine, i put everything new.
Old Sep 24, 2008 | 07:23 PM
1sick68's Avatar
the engine is a LT1 1994 camaro z28 auto, and yes i was sitting in traffic, but everyday im in traffic and just today it started over heating. Motor came from pheonix arizona, ase certified tech put it in for me... legit work...
it just creeped up to 210 and did not mover farther than that. there is also a little light in the center of the dash that came on yesterday its red and has a water level at the bottom with arrow pointing down.... but i check all the fluids and its fine... the engine only has 50000 miles when i got it... need more info let me know
Old Sep 24, 2008 | 07:26 PM
Could it just have been that it was a hotter day today? More traffic than usual heating up the ground a bit more? 10-15* isn't THAT much. Was it more stop and go than usual? All these could factor together to make that small of a difference. I say take it out and test it out a little and as long as all the fluids are fine I wouldn't worry about it too much. If I recall up to 220 is fine (according to owners manual), so unless your getting over that I wouldn't be too worried just keep an eye on the "gages" and make sure fluid are fine.
Old Sep 24, 2008 | 07:39 PM
ss.slp.ls1's Avatar
On a stock tuned LT1, the fans don't come on till 226*F. Regardless of what thermostat you have, given enough time at idle, your car will hover at around 210* or more. As long as it doesn't go past 230, you should be fine.
Old Sep 24, 2008 | 07:41 PM
Your sigs too big
good info
Old Sep 24, 2008 | 07:44 PM
ss.slp.ls1's Avatar
Your sigs too big
good info
Is that still too big?
Old Sep 24, 2008 | 07:50 PM
Looks like it but hard to tell. Can't be over 150 pixels high.
Old Sep 24, 2008 | 07:55 PM
ss.slp.ls1's Avatar
Resized it.
Old Sep 24, 2008 | 07:56 PM
Jeremy 92 RS's Avatar
Resized it.
Shrink it down just a bit more. Sig image max height is 150 pixels.
Old Sep 24, 2008 | 08:02 PM
ss.slp.ls1's Avatar
I think its good now.
Old Sep 24, 2008 | 08:15 PM
1sick68's Avatar
well thanks a lot for the info, one more thing, i have this "sunpro" gage(electric) for the temp, when im on the road the **** jumps all over the place, can the thing not be working right. or should i just get another one...
Old Sep 24, 2008 | 08:24 PM
Jumps all over the place how much? Like 100 to 200? Or like just a lot between 190-210? Is it hooked into the stock location?
Old Sep 24, 2008 | 09:18 PM
impstrz28's Avatar
normal operating temp for an lt1 is 210 so dont worry about that you should be fine. the light that you said comes up is the low coolant light. that light is on all the time in my brothers car and hes coolant is fine also. maybe the low coolant sensor is messed up. dont know bout that one tho.
Old Sep 24, 2008 | 10:50 PM
okay, well first lt1's arent known for running cool, we need some more info on the car, what are you running for coolant?
sounds to me like you need to put a known good mechanical gauge on the engine and repeat the driving you did today to see if its indeed running hot, if your having problems with your sunoco kragen electric temp gauge its probably reading wrong, get a nice auto meter mechanical and start monitoring it that way, as jason said if its around 210 give or take you will be fine, if it gets hotter than that you will need to look at things like the coolant your running, possibly a old radiator cap not holding pressure properly, make sure the front air damn is in place, make sure both fans indeed run, if your still creeping up to a high temp you may need to put a mechanical switch on the fans to keep the temp down as long as possible. their is a million different variables.
