Help Identify the clutch problem
On the same not if you have a stock clutch and ur car is not stock could the power your car is putting down kill your stock clutch? I ask this because i'm putting down high 3's and i have a stock clutch... never acted up when the car was stock as soon as it was making more power it wanted to stick to the floor or would sit down lower than usual? help identify please
Next I would perform the drill mod and see if that cures your sticky pedal.
Finally if that doesn't work I would replace the slave and master cylinders.
Here's a sticky for your sticky problem, LOL:
https://ls1tech.com/forums/manual-transmission/742741-sticking-clutch-pedal-write-up.html
You very well could be killing your clutch with your new found power. I would recommend getting a LS7 clutch kit, it's supposed to be a good, affordable clutch for cars making around 400 rwhp.
https://ls1tech.com/forums/showthread.php?t=742741
As for the Fluid, you can use DOT 4 for the higher boiling point. What happens is that the Exhaust manifold is about 4 inches form the line and causes the fluid in the line to heat up and cause the sticking clutch pedal issue. What I did is wrap it in Thermal Wrap where its under that Metal Shroud on the tunnel.
but you should get some kind of heat shield for the clutch pedal line
Just something else to look at...
here it is i'm pretty sure this is the problem
seems to be leaking from where the clutch housing bolts onto the tranny...
i got sick to my stomach... the bronze piece is where the slave goes in correct???
it seems to be leaking from the seal... wait is there a seal between the clutch housing and the tranny?
Pretty lame but i'm gonna purchase the ls7 clutch and rebuild the tranny since i gotta take it out... first time dealing with the tranny should be fun
or
either way very upsetting The Best V8 Stories One Small Block at Time
like the third pic that is the opposite side of the slave cylinder
