Western Members CA, AZ, NV, UT, CO, NM, HI
tips on how to lower my 60ft.
Old Oct 9, 2008 | 11:58 PM
Raptor_WS6's Avatar
Originally Posted by C5natie
You dont have enough power to break something. You'll be fine with slicks.
i broke my driveshaft with roughly same power some he DOES have to worry a lil bit
Old Oct 9, 2008 | 11:59 PM
camarojunky74's Avatar
if you had a camaro drive shaft that would have never happened
Old Oct 10, 2008 | 12:02 AM
Raptor_WS6's Avatar
, well there is a steel on there right now, so the nextthing that goes is the 10 bolt, when it blows i should put in a camaro on there also huh
, just messin lukey boy
Old Oct 10, 2008 | 12:05 AM
Almostryan3's Avatar
true but when you get even better you stop lifting off the gas while shifting further killing the life expectancy for the clutch and or the rear
If your good enough you shouldn't be shocking the drivetrain during shifting that much anyways
Old Oct 10, 2008 | 12:12 AM
ConElite's Avatar
There is some serious shock to the drievtrain if you know how to shift. I Almost spin going into 3rd. If I had traction on the street, Slamming 2nd is some serious shock and I dont even Powershift like CamaroJunky is saying when one does not lift off the gas when shifting. Makes a huge different, Its very harsh on the drivetrain but makes a diff.
Old Oct 10, 2008 | 12:15 AM
ae13291's Avatar
when slipping the clutch too much the clutch pedel seems to crap out to the floor as well, so keep that in mind
Old Oct 10, 2008 | 12:18 AM
ConElite's Avatar
What do u mean by that? Like you loose pedal and have a harder time shifting?
Old Oct 10, 2008 | 12:20 AM
Talk to 02NBMWS6 about that one, he can shift pretty well without shocking the drivetrain too bad.
Old Oct 10, 2008 | 12:22 AM
ae13291's Avatar
im not sure if u have that problem since u upgraded to the LS7 clutch and flywheel. on my stock clutch when i either drive my car high rpm for a long period of time or slip the clutch too much, the clutch pedal goes to the floor and it feels like there is no pressure in the line, it only lasts like 10 seconds but it can **** you up big time on the track
Old Oct 10, 2008 | 12:48 AM
01SOMSS!'s Avatar
good stuff. i thought 4k rpm would had been too high,but what do i know.
Old Oct 10, 2008 | 12:54 AM
ConElite's Avatar
I dont understand how thats possible but I can be wrong.
Old Oct 10, 2008 | 12:55 AM
  #32
ConElite's Avatar
I doubt the clutch would cause this, I think that would have to do more with the Hydrolics of the clutch not the clutch itself.
Old Oct 10, 2008 | 12:57 AM
  #33
FearTheDeer's Avatar
damn.... Im running 2.2's lol
Old Oct 10, 2008 | 01:02 AM
  #34
ConElite's Avatar
Ha ha ha ha.
Dont feel bad look at my times. When I drag race i wish i had an Auto and stall but im more into handling so Stick is what I need.
Old Oct 10, 2008 | 01:04 AM
  #35
ae13291's Avatar
i dont know man, its kinda like a common problem from 98-02 i did the drill mod and wrapped my lines with 3 different layers of heat resistant stuff and it still does it a bit sometimes and my fluid changes color about every 2 months
Old Oct 10, 2008 | 01:06 AM
  #36
Ha ha ha ha.
I don't feel bad at all. Cuz if Joser and Luis are running same/worse 60's than me. Well then ive got less problems than i though lol
  #37
ConElite's Avatar
U know what the crazy part is, Never once have I experienced this issue. After a pull down the 1/4 it does get a little harder to get into gear but no sticking pedal or anything. ha ha ha
Old Oct 10, 2008 | 01:11 AM
  #38
ae13291's Avatar
i guess david hasselhoff must have put his sacred hands on your car
Old Oct 10, 2008 | 01:15 AM
  #39
ConElite's Avatar
LMAO nice
All my hydrolic components have been charged. Do that, drill mod and LS7 clutch and that will fix your issue!
Old Oct 10, 2008 | 01:17 AM
  #40
ae13291's Avatar
^^ yea i got the drill mod done, i just been waiting for my clutch to go out so i can get the damm LS7 clutch with fidenza flywheel and new GM hydralics
