tips on how to lower my 60ft.
my car is a full bolton car. no cam or heads.I'm running bfg's Dr's 275x40?x17's and most of my 60's are 2.2's. i lower my tire pressure from 22psi-16 psi. i launch at 3krpm.any advice?
I just got some 16'' mt et streets that i'll be using soon. so it should hook a bit better. do you guys think it safe to run them on my car? kinda scared..thanks guys!
Well I made that one easy for you. I know the clock dont start till you leave the line so rt is not a factor. Let me correct myself. I guess I meant just leaving harder off the line would give you a better 60ft. The harder I left the line the better my rt was and my 60ft but I guess that was more good timing than anything else. Nice sig BTW. I dont mind a correction but careful with that stupidity ****. The Best V8 Stories One Small Block at Time
10bolt mt= bad ...u can do it but i wouldnt reccoment launching hard on them.
You need to turn off ur traction control
then
you need a torque arm
LCA's and drop brackets since ur cars lowered.
your springs are really stiff so therefore its gonna be harder to get good launches out of them. hense the reason that alot of drag racers with camaros keep the stock rear springs and put in drag bags.
after these things are installed 16-18lbs of air in these bfgs and 3500rpm launch to full throttle slipping the clutch u should pull off a 1.7...
your welcome in advance
i cut a 1.9 on kuhmo all seasons@ 18lbs dumdumdum
and bleeding it does nothing you need to get a mighy vac.
anyhow, you dont even touch the bleed screw, you suck the bubbles out from the resevoir, the little hole at the bottom, much more effective then trying to get it from the slave.
