1998 NBM with blowby issue inside motor-thining about selling her as it sits
first here's a link to the situation too much crankcase pressure
thinking about moving on and saving up for a house so here's the specs!
The car’s drivable but not advisable. Sold as is
Here’s the specs:
1998 NBM v6 firebird chassis (cheap on insurance!)
A few rock chips on the exterior and a bit of areas the clear coat is fading id say 7/10
Cloth interior, a few stains, rear radios removed, id say 6/10
LS1 wiring harness
01 411 PCM tuned with HP Tuners
Piggy-back air fuel controller-make fueling adjustments on the fly
IAT timing spoof
Very minimal rust underneath
No A/C, air pump, EGR
Engine mods:
01 LQ4
Cam 232/238 .599/.601 113+4
LS6 lifters and 7.4 TR pushrods
Double roller timing chain
Home ported and Milled 0.030 243 LS6 heads with lunati dual valvesprings .650 lift & 0.040 MLS HG
LS2 lifter trays
L67 (42.5lb) injectors
Ported oil pump
LS1 oil pan and oil pickup
LS6 intake manifold
SLP LT Headers ORY pipe Sweet Thunder 18” straight-thru muffler to Walker Dual Outlet Muffler
Trans:
Local shop built 4L60E (cant recall the full specs but shifts on point) less than 1k miles
Spohn driveshaft loop with adjustable TA
Rear:
Moser 12-bolt with 3.73s
misc-set of 16" rim with tires
front sway bar
Here’s the specs:
LS1 wiring harness
IAT timing spoof
Engine mods:
01 LQ4
LS2 lifter trays
Ported oil pump
LS6 intake manifold
Trans:
Rear:
front sway bar
Your descriptive and honest evaluation is welcome. Things sure don't sound good, especially if not advisable to drive the car. Someone that loves to build and work on cars might be interested but this is going to be a really tough sale. It probably won't fetch a whole lot more than 'roller' pricing from what I have learned here over the years. I'd love to give you a solid 'guesstimate' but it seems even they range from $1,000 to $3,000. Hopefully someone else will chime in and give a more accurate number for you. As much as it is a 'pain in the butt' have you considered selling the expensive parts? How much mileage on the Firebird itself?? Too many miles makes it even tougher as everything is wearing out. Sorry about being a 'downer' but I'm sure you know this stuff already. Good luck with your future plans.
thanks for the feedback. i figured it was in the ballpark of a roller. at most i was looking for everything as is is $3k. yea i forgot to put the mileage on the chassis, its at 146k. im the 4th owner and the car originally came from washington state where it had it's v6 to v8 swap (getting into deeper story behind the car-had a ls1 in originally) then went to VA for a short bit then to PA where a local i know bought it but sold it to me in the 2 months he had it(didnt like pontiacs and it was auto). the 98 ls1 spun a rod bearing was when i then swapped in the LQ4.
this is mainly a feeler. worse case is find another LQ4 motor and have my local shop-(when time permits) swap the topend over from the old LQ4 to the new from .
Man, part that car out! Without even thinking about the chassis this is what I think you could get for the mod's you have. Ive bought & sold alot of parts on this site so I have a pretty good idea on what you could get out of the mod's.
Cloth interior, a few stains, aftermarket stereo, rear radios removed, id say 7/10
LS1 wiring harness
01 411 PCM tuned with HP Tuners $100
Piggy-back air fuel controller-make fueling adjustments on the fly - ???
IAT timing spoof
New rear summer tires
Engine mods:
01 LQ4 - needs rebuilt $150
Cam 232/238 .599/.601 113+4 $250
LS6 lifters and 7.4 TR pushrods $200
Double roller timing chain $75
Home ported and Milled 0.030 243 LS6 heads with lunati dual valvesprings .650 lift & 0.040 MLS HG $750
LS2 lifter trays - ???
L67 (42.5lb) injectors $250
Ported oil pump $75
LS1 oil pan and oil pickup $150
LS6 intake manifold $350
SLP LT Headers ORY pipe Sweet Thunder 18” straight-thru muffler to Walker Dual Outlet Muffler $250
Trans:
Local shop built 4L60E (cant recall the full specs but shifts on point) less than 1k miles $500??
Spohn driveshaft loop with adjustable TA - ???
Rear:
Moser 12-bolt with 3.73s $1500
misc-set of 16" rim with tires - ???
front sway bar
LS1 wiring harness
IAT timing spoof
Engine mods:
Ported oil pump $75
Trans:
Rear:
front sway bar
