HELP!! Giving my car away or is it my deal of a lifetime??
sounds like lust to me. With all that money in the car its a bad idea, then again 45g's in a trans-am isn't the best idea either. keep it theres always other cars you might think are nicer, "love the one your with".
Okay..the story is that I didn't put all that money. The guy before me did. He gave it away to me. I don't know why he did it. but he did. So the money isn't a big deal. I'm just attached to my car now. And I don't know where i could find another car like mine. Easier to find another Corvette. So I'm probably going to keep it. What what would be a good trade or sell price though??
Sooooo, you dont want to trade for a car that is worth about 35% more than yours, yet you want to sell it.
I will make it easy for you by letting you ship the TA to me. Then you won't have to worry about it.
Sounds good to me.
Sounds good to me.
here is what you do... trade me your t/a for my t/a then you trade my t/a for the vett
hows that sound.
keep it bro you got a bad car i see more vetts on the road than t/a's
one like your you never see
hows that sound.
Thanks for the help! I treat my car good too. I have never let her see the rain or my the first owner. So it's all good. After college I can get a Vette i guess. After all this my car seems too rare, thanks to all the T/A lovers haha. And I don't wanna sell my car or it would be in the classifieds. THANKS FOR ALL THE HELP! I appreciate it!! My bird is here to stay! Unless someone has a 2005 and up Z06 Vette?!?! Haha Later.
#32
*Slp 1:85-ratio rocker arm
* T-rex camshaft valve lift .590 duration 236* centerline 112* lobe separation 112*
* Comp cams valve spring .600 of valve lift
Um..... Anyone else notice this? Besides blkwdowSS?
#34
#36
A 383 does not make 650rwtq NA. It won't happen. (He did list a stroker crank.. BMEP would be in the 290's.. impossible) His lift numbers are wrong on the cam. Those valvesprings will never control a T-Rex with 1.85 rockers, much less on normal rockers if he is actually using his 8500 rpm shift light. Besides a T-Rex on 1.85 rockers would coilbind springs rated to .600. No one spends that much money upgrading a 10 bolt, a 9 inch is cheaper. Axles and whatnot would be beefed up, but the teeth on a 4.56 gear would be so thin in a 7.5 housing, I don't care what you do, you're going to shear the teeth right off. There are just too many inconsistancies. And there's no f-ing way in hell you are putting that much to the ground through a single 3 inch y-pipe/i-pipe.
#37
There is over $ 45,000.00 in the engine building to make this car what it is today,
ENGINE:
* Comp cams FAST 90/90 polymer intake manifold
* Comp cams fast 90 mm throttle bodie
* Slp Mass air flow sensor 1000 cfm more than stock screen removed
* ls6 oil pump heay duty
* Harmonic balancer/ underdrive pully
* Low temp thermostat 160*
* Titanium valve springs
* Slp manley 5/16 chrome moly push rods (nascar quailty .080 wall
* Double-roller timing chain
* Aluminum connecting rods
* pro comp - steel stroker crankshaft
* Srp bb-high compression forged pistion and rings
* Slp flopac cold air induction
* Nos super power shot nitrous oxide wet /300hp
ENGINE:
#39
Maybe he means theres 45k invested in the whole car? (car+cage+engine mods+fuel system) Anyways, do what you want...we dont have the title to the car. I will say i love the cage in it and what you did with the floor mats in the hatch looks really sweet!
