This is annoying
..........just my 2 cents ive used the hoosiers and they hook good ... i only got a chance to run on them like 4 times because they were my friends ...on his cammed and stalled ta he was grabbin 1.60 60fts no problem
Back in my C4 days, I could launch the car at 3k RPM, dead hook and only get a 2.0 short time because the car would bog down (no power).
Although since you're trapping 109 you shouldn't have that issue. Have you tried to flash it off the line? Launch at basically idle and just mash it, see what happens.
A way to see if you are running correct pressure: Do a small burnout, just enough to leave a mark. Look at the marks and find where the mark is darker, if it's on the sides then you need to raise pressure. If it's darker in the middle then you need to lower pressure. Keep making changes until the tire mark is even across the width.
I had the same thing happen to me, I run low 1.8's 60' with my street tires then switched to too big of a slick (too tall) and I bogged and couldn't manage better than 1.97
If the car is bogging down what could the possibilties be??
I'll try the burnout and messing with the tire pressure. I'll try hiting the track again and flashing it. Never have done it before but i'll see what happens.
Try leaving off basically idle next time and see what happens.
