Billet Specialties Street Lites 15" and 17" Info And Pricing
All depends on what your goal is.
You can do the MT SR radial, ET Front, Sportsman Front, Hoosier, Or the MH front.
I personally Like the SR Front Radial And the 275/60/15 ET Drag radial, Espically if you drive on the street alot.
I run 1/2"x3.47" ARP wheel studs on the rear. Will the Streetlites fit with the bigger diameter studs?
Also, my front calipers are powdercoated and I don't want to grind them if I don't have to. If I use a small spacer will it give me enough clearance so I don't have to grind anything?
I kind of thought the same thing. I just received my 15x10 rears and mounted some hoosiers on them the one thing I can say is looking at them on the internet doesnt do them justice. In person they definitely look like a bada$$ drag wheel.
#32
Just bought a set of these wheels and they look and fit great. Dragwheelz.com
was great to work with. I was happy with the price great customer service what else could you ask for.
Thanks Jason.
Thanks Jason.
#33
Any better pictures of the 17" wheels on a Camaro or Bird from a distance. I've seen the ones on the Monte and they look great; just would be neat to see them on a FBody to get an idea of how they will look (other then close up).
Don't worry either way i'm planning on picking up 2 - 17x8, 2 - 17x9.5, and 2 - 15x10 come tax time. (any deals for buying 6 wheels at once?!?! )
#36
[QUOTE=Dragwheelz.com;10374478]Yes they will.
On the front you can use the 15x4 or the 15x3.5 and the Ls1 specific rear wheels.
It is a Stock Length Rearend in the car. The dish you see is what you get.
Whose Drag Brakes are you running??? if they are strange you should not have an issue, I have heard some complaints of them not Fitting on Aerospace, But other people have not said they had a problem.
You can utilize the regular 15x10 with drag brakes. your price on those would be 230.00 ea shipped to you. here are a few pics with them with Strange Drag Brakes and a narrowed rear end.
[/QUOTE
I finally found the wheels I'm getting!
[/QUOTE
#37
[QUOTE=1fast bird;10387204] Damn !!! That Blue SS is awesome.
Yes they will.
[/QUOTE
[/QUOTE
