Chime in ! Question ZO6 Wheel on a 99 F-body
Old 11-03-2008, 09:24 PM
Mr. Luos's Avatar
I run hub centric spacers on my car.
It cuts 1.72 short times bogging.
Old 11-03-2008, 09:36 PM
Vndcatr's Avatar
Howcome you run spacers curtis ? ..
Old 11-03-2008, 09:39 PM
Mr. Luos's Avatar
To account for heat expansion of the brakes.
I grinded the calipers to fit the 15x10 ProStars without the spacer. But I run it since it is completely legal with NHRA rules and it makes sure I don't get any rubbing once the brakes get hot.
No spacers when I run the TTII's.
And the 27x11.5x15 Hoosiers clear everything without the spacers as well on the ProStars.
Old 11-03-2008, 09:46 PM
DanWS6's Avatar
Old 11-03-2008, 10:03 PM
Mr. Luos's Avatar
Originally Posted by DanWS6
You're confused?
No surprise here.
Old 11-04-2008, 09:54 AM
HUGGER ORANGE SS's Avatar
What size is your spacers Curtis? Looks like I need to run at least 1" spacers, Do more of the B F H mod and roll the fenders with these 19x12 ZO6 Aluminum wheels...
1" spacers seem kinda big to me.
Clint
Old 11-04-2008, 10:37 AM
Mr. Luos's Avatar
Clint
The front ProStars require a 5/8" spacer to clear the calipers...so that up front.
Little smaller in the back.
Old 11-04-2008, 02:12 PM
Which brand of spacers does everyone recommend? Going to do a test fit on these soon.
Clint
Old 11-04-2008, 08:23 PM
will01's Avatar
could have sworn i read somewhere one ls1tech that a .5 inch spacer is needed for the c6 zo6 rims? been searching for the post but i can't seem to find it anywhere...
Old 11-04-2008, 08:32 PM
98Camarod's Avatar
The hub centric spacers, i thought they were only in larger size spacers. I couldn't seem to find any smaller than 1". I'm sure they have limits on the width that you can run vs. the times that you run.
Old 11-04-2008, 09:11 PM
OutKlast's Avatar
C5Z or C6Z?, C6Z I assume because you said 12" wide.
Old 11-05-2008, 11:03 PM
  #32
They are the Origional Stock c6 Zo6 wheels... 18x9.5" fronts and 19x12" rears...
Clint
Old 11-08-2008, 11:42 PM
  #33
DanWS6's Avatar
You're confused?
No surprise here.
Old 11-09-2008, 09:17 PM
  #34
ttt. Fallllk
Old 11-09-2008, 10:31 PM
  #35
lonewolf6.0's Avatar
Originally Posted by 7845
Tucking 325s. I rolled the quarters flat and slightly flared them.. i did the BFH on the inner wheel well and i also massaged the area above the bump stop. [this area where it bulges out some for spring. Besides that im only using a 1/8" spacer thats right 1/8". the rear is a stock LT1 rear. I will need to use tubular control arms along with adjustable panard bar. for the pics i disconnected panard bar and centerd rear up so i can fit wheels.
ok now onto pics
this pic shows the distance between wheel and wheel well
here is proof of tire size
ok pics of car with 300lbs in the rear so it will sit like this at ride height
just empty height again
car is gutted for time being since im rebuilding it
This is that post my buds green camaro with Z06 wheels....
Old 11-09-2008, 11:42 PM
  #36
Mr. Luos's Avatar
You are probably right.
I am probably calling them the wrong name.
I use ones similiar to the upper right ones shown in the pic....
Old 10-01-2011, 12:00 AM
  #37
Bradlyj8Z28's Avatar
how did the rims work out Hugger?
Quick Reply: Chime in ! Question ZO6 Wheel on a 99 F-body
