Slicks or Dr which Are harder on Rear End
A buddy of mine was saying that slicks are easier on the rear since they have give and dont shock the rear end as hard. kinda made sense to me. Whats is your guys opinion on that?
Drag radials are harder on the rear end. Their stiffer sidewalls dont allow near as much absortion on launch like a bias-ply slick would. The softer sidewall of the bias-ply tire allows for some wrinkle resulting in more absortion, being easier on drivetrain components.
[QUOTE=2001z;10600952]This a trick question? radials will spin where slicks will not most of the time so slicks are harder on a rearend. Think your friend is messing with ya.[/QUOTE
I think you should raise your hand to talk. JFWY Really tho man the point is sidewall flex allowing you to hook with out "shocking" the rearend. There are plenty of DR that will hook. Thats kinda why we use them. If they spun....we would just use street tires.
But back to the point. I have c5z06 motorsports and 315/35/17 nittos so you guys agree thats much harder than the 15's and some M/T?
the wrinkel is what makes the slick easier on the rear. a constant load onthe rear does not break them, it the shock. if the drag radials hook, or even spin to a hard hook its harder onthe rear than a wrinkled tire hooking.
I have both and have broke rears, and have tried lots of combos.
