et streets
Old Oct 3, 2003 | 05:05 PM
squirrel masta's Avatar
From: its as intense as the time i forgot how to sit down
Default et streets
will a 26/11.5/16 micky tompson et street fit on a factory Z28 rim
Old Oct 3, 2003 | 10:24 PM
14u2nv's Avatar
Default Re: et streets
YES
Old Oct 4, 2003 | 07:20 AM
4thGENRETARD's Avatar
Yeap, that's what i run.
Old Oct 4, 2003 | 09:32 PM
WILWAXU's Avatar
They'll be TALL.. but work.
Old Oct 4, 2003 | 10:20 PM
or would a 26/10.5 be better, thanks guys
Old Oct 5, 2003 | 08:51 AM
WILWAXU's Avatar
The 11.5's on a 8" stock rim will be close to 27" tall. Bascially taking away gearing. In a 6spd, this isn't as big of an issue as a Automatic.
Old Oct 5, 2003 | 12:24 PM
Not a big issue if you have high stall. Gives a little more trap speed. Effects depend on your cam. They are good with a strong midrange cam.
Old Oct 5, 2003 | 08:00 PM
well its a stock cam i just dont know if the 10.5s will be good enough for my power but i dont want to run out of gear i have 373s now
Old Oct 6, 2003 | 05:42 AM
I used to run 10.5's with stock cam/TC. They work fine but do better with a HI Stall TC.
I set my shift points at 6300rpms and finished in the quarter at top of 3rd.(A4)
Get a line lock to heat them well without damaging your rear brakes. SLP is the best.
