335/30/18 nittos on the back of my ws6?
Old 03-31-2009, 12:30 AM
comanten123's Avatar
Originally Posted by tbird31
I'm with this guy. ^^^
That is a horrible buldge on those Z06s. Those are 10.5" rim the biggest tire you should really even think about putting on that rim would be a 315 and that's still out of it's safety recommendation rage. Primarily a 305 would be what you'd want.
For a 335 tire to be run "safe" you need to run a 11.5" wheel. I contemplated putting a 335 on my 11" wheels but went against it because of the "cloud like" sensation you'd feel in the corner, plus I just think bulge looks bad...that's just me though.
are you serious? 315 is perfect rim size for 10.5. 335 shold have 11".
Old 03-31-2009, 04:59 AM
HWI
HWI's Avatar
I must be really conservative then, using 295's on a 10.5" wide rim.
Old 03-31-2009, 06:28 AM
jerflash's Avatar
thats awesome news man...i did not really want to do any body mods lol
Old 05-04-2009, 12:46 PM
Big_Bird_WS6's Avatar
ok sorry back form dead.
ok tires give a rating on what size rim you should use. like 9-10.5 or whatever. how do you know the best size. should a person just got for the top number. like 275 say 9.5 is max so is that right?
or can i run 9 in with the 275 and be fine?
how do you figure out best number?
Old 05-05-2009, 05:01 PM
any one?^^^^^
Old 07-02-2009, 05:43 PM
SLOC5LS6's Avatar
Originally Posted by 4SFEDZ
here are 335's on my 18x10.5
those are perfect on those wheels
Old 07-02-2009, 06:15 PM
tbird31's Avatar
yes i'm serious, when a tire goes out on you and you're in a ditch because you wanted 20mm more for a look behind your car when you could've gone with a 315 but instead you went with a 335 and had it bulge remember this thread.
this thread is going to continue to go on and on. just look at the factory recommendations and go from there people, don't be greedy. just like parts, you wouldn't skimp on the quality of parts on your car would you? no, so don't skimp on safety, get the wheel widened to the right width if you want a 335, which should be 11.5" or more.
Old 07-02-2009, 06:49 PM
ibex37's Avatar
according to the NITTO web site the narrowest rim you should use on a 335/30/18 NT555R is 11.5 the recommended width is 12.0 and the widest is 12.5
BFG KDW'2 and Michelin PS2's ALSO recommend 11.5-12.5 and Pirelli Pzero's should be mounted on 12-13inch rims. You are definitely outside the recommended widths by at least an inch. the 315's i looked at recommend 10.5 as the smallest width rim to use. so they are also pushing the limits. good luck on your blow out.
Old 07-02-2009, 06:50 PM
HTh3r0's Avatar
good info
Old 07-02-2009, 11:38 PM
99Bluz28's Avatar
Wink
My understanding is that you want a wider wheel for handling, and a narrower wheel for a better ride quality.
Old 07-03-2009, 12:01 AM
So-GT0071's Avatar
I have 18x12's on the back of my truck with 335 nittos. They fit quite well and I don't think I'd go much narrower with the wheel size for 335's. The tires on the green Camaro look like they are bulging a lot to me...
Old 07-03-2009, 12:41 AM
  #32
LS1nut377's Avatar
THE GREEN Z's wheels and tire combo look ****** SICK!!!!!!!
Old 07-03-2009, 08:14 PM
  #33
kbronSS's Avatar
i ran 295's on my 10.5 and were way too thin, i dont like how those 335 look on THAT SIZE rim. but i think 315's would be perfect. we are talking regular tire or dr's?
Old 07-03-2009, 11:52 PM
  #34
LS1nut377's Avatar
**** it im gettin some 335's for my 10.5's
Old 11-07-2009, 08:25 AM
  #35
1slowM6's Avatar
man those tires look good...makes the cars stand out
Old 11-07-2009, 09:46 AM
  #36
tspence45's Avatar
My 335 Nittos don't have much buldge on my 18x10.5's. Here's pics of both of my cars with them.
Old 11-07-2009, 04:06 PM
  #37
DarkJuggalo's Avatar
i had nitto 555r 315s on my 18x10.5 zo6 rims, looked amazing to me...
Old 11-07-2009, 05:16 PM
  #38
Black_Z28's Avatar
Dude, it's not worth your time. I've been trying to tell these guys that a 335 isn't safe on a 10.5" wheel. All they do is, well from my opinion there is no bulge. Then I'll say, well there's recommended wheel widths for tires for a reason. The tire manufacturers didn't just wake up one day and decide they need parameters on tires.
But none the less, they'll do what they want. Then ask for proof as to why they can't run a 335 on a 10.5" wheel. They're the same people that want proof that you can't run a 5x120mm bolt pattern on a fbody.
Quick Reply: 335/30/18 nittos on the back of my ws6?
