Ttii?
Old 04-16-2009, 12:45 PM
beedo's Avatar
Default Ttii?
Quick question, I have been searching for the last hour and no luck. Would a set of 17x9.5 Torq Thrust II wheels,,6" back spacing fit and look right on my 98 T/A? I cant figure out what backspacing needs to be used on the rears.
Old 04-16-2009, 01:04 PM
99Bluz28's Avatar
IMO, 6.75" minimum to 7.5" maximum.
6" will stick out.
Old 04-16-2009, 02:26 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
PM Dragwheelz they'll set you up
Old 04-16-2009, 03:30 PM
Camaro396's Avatar
6" will stick out.
You can't get a 17x9.5 Torque Thrust II in 7.5" backspace. 7.375" is the most you can go.
Old 04-16-2009, 04:24 PM
udienow's Avatar
Im fairly sure you want the 17x9.5 in a 7" backspace.... about +46mm offset... thats what good on the front anyway... i assume rear would be indentical?
Old 04-16-2009, 05:42 PM
beedo's Avatar
Just asking cause there is a guy selling them whhels and tires for 500 in good shape. For 92-02 fbody but I thought that the 93-97 had different rears, but the longer I think about it they were the thirdgens that had different diffs. Anyway, I will pass on them cause I really dont want them to look f'ed up in the rear
