Wider stance with C5 Z06 rims
I use a 53 offset and I'm fairly low. Had to roll my fender lips, bang on the inner fender and I had to put together an adj panhard rod to get it so it didn't rub. Mine are 18x11s though.
Are you sure the drivers side doesn't stick out abit? I suspect it does and that's why the side you have a picture of is spaced in a bit.
It also could be that it fits fine and it looks spaced in too far because your car is high enough in the rear that you see more of the tire.
It's a bit hard to tell with pictures cause the angles and lighting can be deceiving.
