Z06 Wheels In 2002 Ss
Your speedo will be affected a little bit. When your speedo says you are doing 50 mph, you are actually doing 50.91 assuming you are using the 295/35-18 with the Z06's and currently have the 275/40-17's.
Hope this helps.
Hope this helps.
Second - all caps mean you are yelling at us . . .
Third - the fronts will mount right up - no issues, althouhg it would behove you to buy new front tires that match the OEM front diameter - F-Body ABS is not desisign to take into consideration different tire diameters. In the back the inside of the tire may rubb the inner wheel well surface during turns, you will hear it. Take the wheels and tires off, you will see in the undercoat areas where the tire has contacted the wheel well housing - massage -more like beat those areas in with a nice big hammer, re under coat and you'll be good to go.
