tire width?
Old Nov 18, 2003 | 11:38 PM
Cummins's Avatar
Lightbulb tire width?
how wide of a tire can i throw on a 8.5" or 9.5" rim? 295s? any ifo would be helpful thanx.
Old Nov 19, 2003 | 09:44 AM
Wesley SS's Avatar
on the 9.5 you can fit a 315's
on the 8.5 you can maybe fit 275's
Old Nov 19, 2003 | 01:28 PM
Xsta Z 28's Avatar
Per manufacturer recommendation a 275 is probably the widest on a 8.5" rim. 285 on a 9.5" rim.
I would NEVER put a 295 or a 315 on such a small rim. Defeats the purpose, is not recommended, and in short dangerous.
295 require a 10" rim minimum and a 315 requires a 11".
Your car, your life.
Old Nov 19, 2003 | 04:39 PM
Wesley SS's Avatar
I had 315 drag radials on my 17x9 SS and they were fine they stuck out a little past the rim. So just a question whats wrong with a wide tire on the back because i could understand your reason for the front but not the back?
Old Nov 19, 2003 | 05:02 PM
skippytheloon's Avatar
I was simply told one size bigger than recommended is okay, anything more can be dangerous.
Old Nov 20, 2003 | 09:17 AM
Xsta Z 28's Avatar
Originally Posted by Wesley SS
. . . . So just a question whats wrong with a wide tire on the back . . . ?
There is absolutely nothing wrong with a bigger tire AND WHEEL out back than up front, but when you have a big tire forced onto a wheel that it was not designed to fit on, you are exerting forces onto the tire beyond what is is capable of withstanding.
Cramming a 12" wide tire onto a 9" wide wheel forces the sidewalls and corners into an undesigned shape and can cause a premature failure - and flying down the expressway and have a tire prematurely fail is not my cut of tea.
Can I remind you of Ford Explorer and Firestone? A perfect example of "forcing" a tire to do something it isn't designed for.
Like I said your car, your life.
Old Nov 24, 2003 | 08:51 PM
Cummins's Avatar
thanx for the info guys :jester:
