Pro Star wheel stud problem need some help
This would not be the case for your setup though...just thinking out loud for others who have stripped wheel studs with other wheels.
If you're installing studs by pulling them in with a nut...and using over 100lbs of torque, you're probably stretching and weakening the studs. Generally speaking, never pull studs into place if you have to exceed the torque rating of the stud. This is a main reason why you're supposed to press the studs in place. This may have been your problem.
Then while driving the lugs were distorted by the wheel moving around . . . ?
