How do I roll my fenders?
[QUOTE=01Z28M6;12460614]Be sure to cut the paint along the bend line. I lost a good deal of paint when rolling the lip but it was all on the inside of the bend line. Here's my experience using a borrowed fender roller. It was an easy thing to spray paint from a can where the paint flaked away Notice the fine line where I cut the paint with a razor.
QUOTE]
I didnt cut the paint and mine are absolutely perfect...as long as you use the heat gun and take your time nothing will flake off. mine look completely factory
QUOTE]
I needed every millimeter of space and that is why I folded mine against the inside. Bending up to 45 degrees simply wouldn't create enough clearance in my situation.
