Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
- Camaro and Firebird: Tires General Information and Specs
Step by step instructions for do-it-yourself repairs.
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
#305
I was wondering about putting C6 wheels on a camaro. The wheels are 18x9.5+57 up front with a 275x40 tire up front, and 18x10.5+58 with a 285x40 tire out back. Since the offsets don't fall on the chart, what would need to be done to make them look flush? Whould I also have to roll the fender lip and use the BFH. Just a little confused which would have to be done.
#306
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
Tires, are all wrong IMHO, 275/35ZR18 front and 295/35ZR18 rear . . . the side walls you state are too tall.
#307
Looking at the same size on my slightly lowered 95 LT1. Will the sizes mentioned above fit without rolling the fender? Would it require the BFH mod since it tucks in so far?
#308
18x10.5 58 mm offset Z06 with 305's-315's (GSD3) in rear (I know gsd3's run wider)
(looking at tomzwheels)
How hard is it to get those to fit, would it be better to go with something such as a 295?
#309
#310
#311
I have 18x10.5's with 315's in the back, i was wondering if 19x10.5's with 305's would fit without a problem. I'm pretty sure they will fit but, while im posting, i'd might as well ask, will 18x9.5's with 265's fit in the front?
#312
I'd run a 275/35ZR18 upr front, and again offsets . .
#314
Originally Posted by ultraz
I would like to know the widest i can go with chrome replica C5 rims which are 17x8.5 all around with 56mm offset.............. any info will be greatly appreciated.
#315
I just ordered a set of four 18x9 wheels. I'm trying to decide between 245/45/18s and 275/40/18s. TireRack said the latter would be a tight fit up front. Should I just go with the 245's?
#316
#318
i got the offsets for the 19x11 rear Z06's (+64mm) and 18x9.5 front (+54mm). What tires and sizes would be the best fit, that is, if you think those rims would fit...thanks again.
Going to need a spacer.
#319
i have two spacers on each rear wheel already, each are 5/16'' if im not mistaken. 325's?!?!? thats F-in awesome as long as they fit! There isnt a 30 profile for the front or 25 profile for the rears?
#320
I just ordered some Boyd Rebels yesterday. 9.5's in front and 11's rear. Boyd recommends 7 3/4 BS for the rears but that to me is only a +32mm offset. Is this correct, I don't want them to stick out past the wheel well.
