Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
- Camaro and Firebird: Tires General Information and Specs
Step by step instructions for do-it-yourself repairs.
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
#481
I am looking at two sets of wheels, but I will limit myself to only asking about the one right now
I am looking at the iForged 2 piece Racing Series, they are only offered in 7, 8, 10, 12 in 18"s and 17"s
so I was thinking about running a 17x10 in the front and 18x10 in the rear,
my Formula is lowered, will I have to do any modification to fit these?
and what are the typical back spacing and off sets as well as lip size?
#482
I do not recommend 10" or larger wheels up front unless you are die hard autocrosser . . .
I personnaly cant stand the 17/18 combo on F-Cars . . . but anyway.
A 10" wheel in back can handle on offset of around 35 mm . . . up front I do not know.
#485
There is not "typical" offset per say . . .
these wheels are at the maximum of my budget.
and unless you get the 3 piece from iForged, they only offer 7,8,10, and 12 inch widths on the racing series
#486
that's a great little chart, although it doesn't unfortunately have the smaller stock wheel, the 16x8. Does anyone know what the offset on those is? I'm trying to do the math on some new wheels to see how much they'll stick out in comparison on my 01 TA.
-sectari
-sectari
#487
I just got a set of Z06 wheels, the rears are a 18x10.5 with a 58mm offset. I have a 98 Camaro. Was wondering if I should just get a set of 1/4" spacers and will I have to do any other mods in the wheel well? Also, will the studs be long enough to thread without any risks of the wheel falling off?
#488
#489
well if the 17/18 combo looks bad on the Fbody, what would you recommend?
The 17/18 looks fine on the Vette because it was designed that way and the tire are different in diameter too.
F-Cars, really shouldn't run different diameter tires cause the ABS is not programmed to "see" that difference. So the side wall for the front tire is taller than the rear side wall and looks silly to me . . .
#490
Thanks, I have decided not to go with different diameter rims, either 18" 2 piece iForged Evolves or 17" Boyds Rebels
iForged would be 18x10 and 18x9; Rebels would be 17x11 and 17x9.5
just not sure if I want to pay more for tires, 17x11, or more for wheels, iForged
#493
would a 15x10 american racing tt2 fit and clear the caliper? would 315/60R15 fit on it? without rolling fenders etc? sorry if this was posted before, i have a hard time understand tires and rims etc
#496
#498
My friend is looking into getting some Cragar chrome rims for his 94 LS1 swapped camaro. If he wants to get some wide tires on the back such as 315's, what do you guys suggest? 15 x 12? Would there be any clearance issues anywhere?
Also do 15" cragars still look good?
#500
I have some 18x9.5 c5 wheels that I am going to get a set of 1/2" spacers for the rear of my t/a. What length of ARP studs will I need? I have seen 2.5" & 3.25". Also the Baer spacers are the only (non cast iron) ones I have found...are they alright? If the Baers are not any good will you please direct me to a specific place to get some better ones.
Thanks in advance
Thanks in advance
