Old 04-26-2016, 02:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
Print Wikipost
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
Old 12-11-2006, 08:15 PM
  #641
F-117HWK's Avatar
Originally Posted by Xsta Z 28
Diameter of the wheel has nothing to do with rubbing issues, since one is supposed to get skinner tires so that the overall diameter of the tire si as close to stock as possible.
Beleive me I know what it is like to unload $4,000 on wheels . . .
Yea you do, and it most certainly looks like money well spent if I do say so myself.
So basically I think Im gonna go with the 18x10's with 275's in front then 18x11 in back with 295's. Hopefully everything will work out when its said and done.
Thanks,
Jason
F-117HWK is offline
Old 12-13-2006, 12:56 PM
  #642
Hoostompa's Avatar
I'm looking to mount a set of C6 motorsports 18 x 8.5 56mm offset on an 02 t/a, all around. Been thru the threads, eyes burn, nothing on this set up. Will the set up fill out the fenders properly? What spacer if not? I assume they will sit close or exact to the factory wheels set up. Also whats my tires size option.
Hoostompa is offline
Old 12-13-2006, 01:54 PM
  #643
Xsta Z 28's Avatar
No they will not filll the wheel wells, the wheels are 1/2" narrower with the same offset as stock SS wheels . . . so they will be tucked in about 1/4" more.
To give the illusion of filling the wheel well, you'd need about a 18 mm spacer.
Xsta Z 28 is offline
Old 12-15-2006, 09:04 AM
  #644
Hoostompa's Avatar
Xsta Z 28. Been doing my math & drawing to get this offset/backspace vs rim size & width down. Correct me if I'm wrong. C6 motorsporst 19 x 9.5 +63mm offsett all around: I show these will fit a TA with little/no need for a spacer on 245/35 tires. If I added a spacer of about 1/4" it would push the wheels out slight past stock & there should be no mods needed either way?
Old 12-15-2006, 11:01 AM
  #645
Xsta Z 28's Avatar
Exclamation
Well stock wheels are 9" wide and have a 56 mm offset . . .
The 63 mm offset will move the wheel inwards by 7 mm, and there will be a 1/4" more wheel inside.
So to fit, a 1/4" spacer would be the minmum required, that would net you a 57 mm offset. . . . a 1/2" spacer would look better or a 3/4" even more , but you would need to replace your lug studs or get adapters.
A 245 will not fit a 9.5" wide wheel. A 275/30ZR19, is the preferred tire.
Old 12-15-2006, 11:40 AM
  #646
Hoostompa's Avatar
Thx again. At least I know I'm on the same page although I was off somewhat in my diagram I drew up. Damn cheap ruler........ thx again
Old 12-19-2006, 06:14 PM
  #647
ruquick02ls1's Avatar
Could someone please tell me if these rims will fit?
I went to a local wheel and tire shop and asked about some Z06 wheels for my 02 camaro and he told me that he could get them in 17 x 9.5. I asked about the offset and he said they was 42mm. That just sounds weird to me being i have only seen them in 54 and 65 at Tomzwheels.
Thanks for any help
ruquick02ls1 is offline
Old 12-20-2006, 08:52 AM
  #648
Xsta Z 28's Avatar
Thanks for any help
If they are truely 42 mm offset, they will fit just fine. They actually will look pretty darned good, filling the wheel well out.
Old 01-20-2007, 03:09 PM
  #649
TuffSS's Avatar
How would 19x8.5" (38mm offset) and 19x9.5" (45mm offset) fit on my recently acquired (black) 2000 SS.
Thinking about these............(they come with a differenct center cap than the one pictured)
I realize the bolt pattern issue, but .....still considering.
Wondering how they'd fit relative to the outside of the body, and what tires I might be able to get away with (thinking wide/tall (27 to 28" tall if possible)).
Any input/help really appreciated, thanks.
Was thinking 5 spokish, but now thinking of something different like above.
Also, thinking of a color flip. As in center not black, but rim in black. Again, on my black SS.
TuffSS is offline
Old 01-20-2007, 03:14 PM
  #650
TuffSS's Avatar
Just noticed again, what wheel is that in your avatar Xsta Z 28? Looks like almost the same thing I just zeroed in on.
TuffSS is offline
Old 01-20-2007, 04:35 PM
  #651
Xsta Z 28's Avatar
Exclamation
Your above listed offsets are fine.
The wheel in my avatar is a Fikse Profil 13, which I have on my Red Convertible SS.
Old 01-20-2007, 04:45 PM
  #652
TuffSS's Avatar
Thank you.
How about 19X8.5 FRONT AND 19X10 REAR, F 35MM-35MM-R
TuffSS is offline
Old 01-22-2007, 12:13 AM
  #653
BatmobileSS's Avatar
Who can help me decide on tires?
What I have in front is a 17X9 +45 and the rear is a 17X10.5 +44
What size tires should I be looking for? I do want the rear to be wider.
BatmobileSS is offline
Old 01-22-2007, 08:30 AM
  #654
Xsta Z 28's Avatar
Front 275/40ZR17
Rear you can run up to 315/35ZR17
Old 01-22-2007, 08:32 AM
  #655
Xsta Z 28's Avatar
Thank you.
Still should be fine. The 35 mm offset rears get tight.
Old 01-22-2007, 08:34 PM
  #656
F-117HWK's Avatar
Hey yall,
Quick question...
Would a double-adjustable panhard bar be a smart purchase when changing over from stock 16 inchers with 245's to 18x11 CCW's with 295's? Just had heard some people mention that this is a very good thing to buy and can eliminate some problems with fitment issues. But, I dont know for sure so let me know any info yall may have.
Thanks,
Jason
If this is the wrong place to post this Im sorry and let me know where it would be better suited.
F-117HWK is offline
Old 01-22-2007, 08:42 PM
  #657
TuffSS's Avatar
Thank you.
Rears get tight as in sticking out to far?
TuffSS is offline
Old 01-23-2007, 08:30 AM
  #658
Xsta Z 28's Avatar
Thank you.
Correct.
Old 01-24-2007, 03:43 PM
  #659
LT1wannabe's Avatar
I want to order some wheels from Tomz (18"x8.5" C6 Motorsports), but the wheels are offset 56mm, and the thread says that the range for my car ('00 bird) is a little less than that. What do you guys think?
LT1wannabe is offline
Old 01-24-2007, 04:02 PM
  #660
Xsta Z 28's Avatar
They have about the exact same offset as the OEM 16" wheels on "birds".
Quick Reply: Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
