Old 04-26-2016, 02:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
Print Wikipost
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
Old 08-23-2004, 01:52 PM
  #81
Xsta Z 28's Avatar
Exclamation
Originally Posted by B00SS
I'm sorry, I don't even know what the stock offset is, so I will just ask. My friend is trading in a ’93 vette. It has the 285/40/17’s I have an opportunity to get these for nothing. We will just swap before he trades. Will these fit my stock chrome wheels from my SS and will my 275/40/17’s fit his stock wheels? I really don’t want to take a hammer to my car. I need to move on this deal quick, so any help would be greatly appreciated.
Are you talking wheels and tires or just tires????
Stock Camaro offsets are around 50 mm to 56 mm.
Stock 93 wheels should be a 56 mm offset (from what info I've found)
The tires are completely interchangeable, the 28's are going to a be a little taller and wider than stock, but the diff is pretty negligable . . .
Xsta Z 28 is offline
Old 08-23-2004, 02:20 PM
  #82
B00SS's Avatar
Just tires. Thanks a million, Andy.
B00SS is offline
Old 08-23-2004, 11:22 PM
  #83
chrismcdaniel's Avatar
ok, im tired of readind through all of these post to try and find the answer im looking for. So, i hope this gets looked at way at the back of this thread.
I know nitto's run narrower than othr tires but is still unsafe to run 315's on stock ss rims, but what about on a 10 inch rim? i found a good deal on these.
american racing rims from a friend of mine and they are all 17x10. i was only going to buy them if i could run 315 nittos on them. i know several guys who i can only assume are lucky because they run 315's on stock zr1's and have never had a problem. but i wanted to make sure it was safe. so, can some one fill me in.
i saw the first page post that gave ranges for rims, but i dont understand why 9 inch tires have the same max tire size as a 10 inch tire.
chrismcdaniel is offline
Old 08-24-2004, 08:09 AM
  #84
Xsta Z 28's Avatar
Technically no, manufacturer recommends an 11" wheel.
Old 08-24-2004, 08:52 AM
  #85
HOSS99's Avatar
Check the nitto site http://www.nittotire.com.
If you look at the recommended rim size for the 315, I think it recommends 10,11,12, with 11 being the measuring rim.
HOSS99 is offline
Old 08-24-2004, 09:21 AM
  #86
Xsta Z 28's Avatar
Nitto 555R - 315/35 R17 Recommended wheel widths (10.5)-12.0
So I guess we are both wrong
Heres the specs: http://www.nittotire.com/popup_555r_sizes.asp
So, technically they do not fit 10" wide wheels . . . .
Old 08-24-2004, 09:30 AM
  #87
HOSS99's Avatar
Dumb question ... Are the stock SS Rims 17 x 9 or 17 x 9.5? I've read both but never measured.
HOSS99 is offline
Old 08-24-2004, 10:21 AM
  #88
Xsta Z 28's Avatar
As far as I know they are 9".
http://www.slponline.com/view_produc...RTNUMBER=80041
Old 09-13-2004, 01:54 PM
  #89
02 Camaro SS's Avatar
Would i need to make any other modifications other than BFH to fit 17x11 ZR-1s with 315/35-17s on the back only?
02 Camaro SS is offline
Old 09-13-2004, 02:14 PM
  #90
Xsta Z 28's Avatar
Exclamation
If you are lowered you may need to consider rolling the quarter lip aswell.
Old 09-20-2004, 08:48 AM
  #91
HOSS99's Avatar
Would this fit without the BFH mod?
M&H DR 275/50R17 28inch Dia. Seems like the perfect tire if it fits.
HOSS99 is offline
Old 09-20-2004, 03:32 PM
  #92
Todd@AZPowerAndSound's Avatar
thats a damn tall tire. I definitly would say you would have some problems
Todd@AZPowerAndSound is offline
Old 10-04-2004, 07:00 PM
  #93
NoFear95's Avatar
Whats the skinnyest Rim that would clear 2003 Zo6 Brakes on a 1995 Trans Am?
Looks for a front runner that will clear those brakes.
NoFear95 is offline
Old 10-04-2004, 09:41 PM
  #94
Xsta Z 28's Avatar
Width isn't the issue, it's diameter. I beleive 17" is the smallest diameter, then with the width, it is a matter of offset and backspacing . . .
Old 10-05-2004, 01:09 PM
  #95
NoFear95's Avatar
ANy idea of what that would be......?
NoFear95 is offline
Old 10-27-2004, 02:59 PM
  #96
Schon's Avatar
I'm considering running 17x9 with a 25mm offset in the front, and 18x10 with a 41mm offset in the back. I'm pretty sure these will fit but I want to make sure the fronts wont stick out. Also any tire width recommendations for front and back? My car is not lowered and I'm looking for a larger diameter than stock wheel/tire combo to fill out my wheel well a bit.
Schon is offline
Old 10-27-2004, 03:05 PM
  #97
the rear should be fine...will need to roll the fender. But the front will stick way out. Gotta get above 40 up front
Old 10-27-2004, 03:12 PM
  #98
Schon's Avatar
thanks for the fast reply. that sucks though because I dont want to run 18's up front and the AR rebels dont come in any different offset for a 17".
edit
more to the point I dont want an 18x10" up front.
Schon is offline
Old 12-01-2004, 03:22 PM
  #99
RickO's Avatar
Okay, I read and I read. Then I read some more.
I have to ask. I want to change the wheels on the 2000 SS convertible. This change needs to be done in a cost effective way so I will not be going out for Budniks or, dare I say, HREs.
I've seen in Super Chevy Performance Wheel Outlet but they do not reference a website. I'd be more than happy to utilize a sponsor also.
They, PWO, have three five spokes that I think I like.
The Y2K at 18x9.5
The Milan at 18x9.0 (I think)
The Vortek at 18x9.0
All three of these run between $250 - $260 a piece.
With no insult to those of you who have them, I like the Y2K the least only because the spoke come all the way out to the front of the rim.
My questions are.
1. Do any sponsor sell these rims? (T Byrnes sell Y2Ks but not the others)
2. Will these particular rims fit on my car?
3. I'd be happy to hear suggestions on tire size and type.
Rick.
RickO is offline
Old 12-02-2004, 11:41 AM
  #100
Steel28's Avatar
Default What is flush
I wanted to buy some american racing hopsters and these are the offsets +46,+32,+28mm which one of theses offsets look flush in the front and look flush in the back. I have a set of c5 and the front are a little in the fender and my friend has a set of zo6 rims and his front ones are flush with his fender.
Steel28 is offline
Quick Reply: Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
