Rough guess on spacer size for 18x10.5 on front and tire question
Old 12-10-2009, 12:13 AM
ben77's Avatar
ZL1LT1^^^^ has 295's all the way around on a camaro.
Old 12-10-2009, 05:38 AM
vatechguy3's Avatar
i bought 295s all around, but oe wheels forgot to include the valve stems. just got them in the mail. hope to get a trial fit up this weekend.
going to try 5/16 and 7/16 spacers for starters and see what happens. won't drive with those, but since they are cheap, should work well for checking fit.
tony
Old 12-10-2009, 05:41 PM
AZ2ENVY's Avatar
Actually I have 295's on the fronts and 335's on the rears
Old 12-10-2009, 09:54 PM
vatechguy3's Avatar
i saw you said you were running 1/4" machined spacers. can you post a link for where you got them please?
also, can you post some pics of how the tires/wheels fit the wheel wells? are they flush with the upper fender/quarter panel, or are they slightly recessed?
thanks
tony
Old 12-10-2009, 10:10 PM
ben77's Avatar
LOL my bad. 335's look MEAN as hell on a fbody.
Old 12-10-2009, 10:13 PM
ben77's Avatar
1/4" spacers on the 18x10.5 with 56mm offset will still be very recessed. Nowhere near flush. Like I said, I just put on 1" spacers, with 295's, and now they are flush in the rear.
Old 12-12-2009, 08:48 PM
OreoLt1's Avatar
Well got the C5 DD 18x10.5 ordered with 295/35/18 all around. Ill get them mounted and test fitted and see where I need to go from there. I'll let you guys know where I stand and post pics for future refrences for anyone else that may have ?'s
Thnaks for all the input!
Old 12-13-2009, 07:50 AM
vatechguy3's Avatar
should be test fitting mine wheels today too.
should be posting results tonight.
tony
Old 12-13-2009, 10:04 PM
vatechguy3's Avatar
tried the 5/16" spacers out front and rear.
could barely get my finger between the knuckle and rim up front and seemed to be adequate clearance in the rear.
auto parts store didn't have the 7/16" in stock like they told me on the phone they DID have in stock....jerks! so didn't try out the 7/16" yet.
either way, definitely need longer studs.
anyone else have any luck?
just how much clearance do you need?????
thanks
tony
Old 12-14-2009, 08:11 PM
OreoLt1's Avatar
That sucks and I know all about the parts store issues!
Definately interested to hear what length lug studs guys are using on similiar set ups!
Old 12-14-2009, 08:22 PM
vatechguy3's Avatar
i believe the answer is arp 2.5" studs.
hopefully someone else will comment here too.
still curious to see what spacers others are running for the fronts and rears too, with a lowered car.
tony
Old 12-14-2009, 08:24 PM
  #32
vatechguy3's Avatar
can you post a pic of the front and rear looking down the side of the car?
tried 5/16" front and rear and they looked pretty far out there!
thanks
tony
Old 12-15-2009, 02:17 PM
  #33
ben77's Avatar
Here are a couple of pics with 25mm spacers in the rear. The other pics in my 'fall pics' album are with 7/16" spacers if you wanna make a comparison. I would try to get better pics but as you can see this cars not goin anywhere for a bit. I still need to adjust the phb to move the body to the drivers side about 1/8" as well.
Old 12-15-2009, 08:50 PM
  #34
vatechguy3's Avatar
did you need that much clearance, or just like the look?
thanks
tony
Old 12-15-2009, 10:46 PM
  #35
ben77's Avatar
Nah, 1/4" spacers should be fine for clearance. I just hate the tucked look. After I adjust the phb it should only tuck in 1/4 inch if not less.
Old 12-16-2009, 06:30 AM
  #36
FrankSS's Avatar
i have the 295/35/18 and 335/30/ 18 on mine... have the 18x10.5 c5 DD... and im not running any spacers yet, and just had to do the BFH... i think all i need is a 1/2-3/4 in spacer to bring mine out to be flush
https://ls1tech.com/forums/12177404-post92.html
Old 12-16-2009, 02:28 PM
  #37
ben77's Avatar
Yea def, with 335's i'm sure all you need is a 7/16" spacer to be flush.
Old 12-17-2009, 07:47 AM
  #38
ssfast99's Avatar
If i were u guys i would run the 3" arp studs like i did which worked great. for more people who wanted pics of the 335 on an f body here you go.
Old 12-19-2009, 06:59 PM
  #39
OreoLt1's Avatar
Well got the wheels and tires mounted and balanced and test fitted and suprisingly the rears fit without an issue! The fronts needed a 5/16in. spacer and longer studs and fit so far.
I have not driven the vehicle yet cause I'm waiting on more stude from the parts store but have run into a major issue on the front..... On hard turns all the way from lock to lock the tires do not clear the front bumper and wheel wells. I had to take the ground fx off of the front to gain more clearance but still have to do something about the well and bumper edge.
Anyone else run into this issue?
Old 12-27-2009, 12:35 PM
  #40
vatechguy3's Avatar
got any pics yet?
i will need at least the 5/16 spacers for the rears, not sure of the fronts yet.
i've been sick, so haven't done any work lately. hopefully will be working on the car some tomorrow.
tony
Quick Reply: Rough guess on spacer size for 18x10.5 on front and tire question
