15x10 + Nitto DR 275-60-15 yeah or nay?
LS1Tech Co-Founder
Will that combo fit?
I know that Larry at www.ls1speed.com has a set on 15x9.? Bogarts.
Anyone have any thoughts?
They have basically 3 sizes. 15x8, 15x9.75 & 15x10
From what I've seen, the 275/50* 15 is about the same size as a 26x11.5 ET Street. Mickey Thompson has a handy chart on their website.. unfortunitly it's down right now.
*edited
Off the Drag Radial Press Release:
Part# Size Equivalent
3752R P235/60R15 26x9.50-15
3753R P275/50R15 26x11.50-15
3754R P275/60R15 28x11.50-15
3757R P325/50R15 28x13.50-15
3762R P295/65R15 30x12.50-15
3763R P315/60R15 30x13.50-15
3793R P255/50R16 26x10.50-16
3743R P275/40R17 26x11.50-17
http://www.mickeythompsontires.com/press_11_17_03.html
So the 60 = 28x11.5
So the 60 = 28x11.5
When I had my 275/60/15 Nittos, I wanted to run them on a 15x10 Pro Star. I couldn't find anyone that had, so I looked around the Mustang forums (there are alot of Mustang DR racers) and found out that a 275/60/15 would look "balooned and spread out" on a 10" wheel, that it is more made for an 8" wheel. Attached is a pic of a 275/60/15 on an 8" wheel, you can see that 2" extra would spread out the tire too much. The Mustang guys recommended the 325/50/15 BFG DR (27.9" dia, 10.4" tread width, 13" section width, all measured on a 10" rim) on a 10" wheel. (I already had the 275s, so I just got the 8" wheels). Look around the Mustang boards at the DR class sections, there is a ton of pics and info there.
Shawn
Shawn
The combo will work but not a good choice IMHO. Your looking at a x-sectional area of about ~10 3/4 inches. This doesn't provide very good clamping force which helps prevent tire slipping @ low pressures.
I am not a tire dealer, but I would imagine that this tire isn't recommended for a 10 inch rim...you may want to verify. If it was, it would definitly be at the very edge of the aceptable range.
i will work and the 15x 10's are a much MUCH better choice for the 275's i've done SEVERAL of these setups, both 15x8 and x10's. do what you like but i'll go ahead and say "i told you so" ahead of time. its like a 275 on a 17x8 mustang wheel that is made for a 245. granted these are 40 and 45 series tires but it's the same concept. it will fit but it's balooned over and your contact patch is even less.
