30, 35, or 40/18?
Old Apr 19, 2010 | 08:20 PM
Daez's Avatar
Default 30, 35, or 40/18?
I want traction, and will be getting drag radials between 305-315 for my 10.5 inch wheels. Now I need to decide if I should get 30, 35, or 40 height. My car has 3.23's in a 6 speed(roll race only car), I will not launch this car prolly ever(At least on this rear end), but there will be alot of spirited driving including in first gear. Will the smaller side wall of a 30 make much difference? How much does each tire size change the final drive ratio?
Old Apr 19, 2010 | 10:48 PM
someday's Avatar
none of those sizes will give the correct tire height...
295/35x18 is 26.1" (closest to stock)
305/35x18 is 26.4"
315/30x18 is 25.4"
315/35x18 is 26.7"
Old Apr 19, 2010 | 11:22 PM
SHovV's Avatar
you, my friend, need a 345/35/18. Let 'er rip!!
Old Apr 20, 2010 | 03:36 PM
someday's Avatar
345/35x18?? thats 27.5" tall... did u mean 345/30x18? thats 26.2" tall, a BFG drag radial... but a 345 tire needs at least a 12" rim...
Old Apr 20, 2010 | 03:40 PM
youngrigo's Avatar
Im probably going 305/35x18 in the rear with 285 or 275/35x18 in the fronts.
Old Apr 20, 2010 | 03:48 PM
Daez's Avatar
Stock height doesn't matter to me, but why does the height of a tire go up when the width goes up?
Old Apr 20, 2010 | 03:52 PM
youngrigo's Avatar
O- Nitto DRs in the rear and Nitto 555 in the front btw
Old Apr 20, 2010 | 05:36 PM
Johnnystock's Avatar
The Q is more like what brand will you take? From my personal exp, I recommend Avon tech M550, BF goodrich g force summer; very sticky from any speed roll! 1st is more though for manual, but youre auto so you should be good! I dont think you need DRs, unless at high hp levels.
Old Apr 20, 2010 | 06:48 PM
someday's Avatar
the height goes up because its a percentage of the width... thats y u lower the ratio when u goto a larger diameter... 275/40, the height is 40% of the width... 275/35, the height is 35% of the width... 305/35, the height is 35% of the width, and 305 is larger than 275...
Old Apr 20, 2010 | 08:43 PM
los p's Avatar
the 305/35x18 is going to rub slightly atleast it did when i tried mines on today
Old Apr 21, 2010 | 12:44 PM
youngrigo's Avatar
BFH mod is needed.... Im running 315/35x17 right now and i know the 305/35x18 are slightly taller.
Old Apr 21, 2010 | 02:53 PM
Daez's Avatar
My car is a 6 speed(with 3.23's, swapped rear). It's already modded(hammered/rolled) to run 345 slicks, so not worried about any of that really. The car will be at about 425 to the wheels on motor, with a 150 shot soon after the wheels get on it.
I've been seeing some pictures of a 335 on a 10.5 inch wheel and it actually looks nice, wondering how safe it is for cornering though.
Old Apr 21, 2010 | 03:38 PM
808z28camaro's Avatar
Tire height will matter because of 2 reasons
1. You gear ratios WILL change/ (in a good way or bad), speedo will be off without proper tuning,
2. lower profile tires= less side wall flex= better handling, but less hooking traction.
Old Apr 22, 2010 | 01:01 AM
nicefingbod's Avatar
I've seen a few pictures as well of 335(nitto)on a 10.5 c5 deep dish and it looked real nice. I'm getting those deep dish c5 next month and I'm looking for a similar tire
Old Apr 22, 2010 | 12:44 PM
youngrigo's Avatar
Im with you guys... Im really debating on the 335/30x18 Nitto DR's on the 10.5 rim
