will these nitto dr's hook better than my 315 sumo's?
if i heat mine up real good they will allmost dead hook.
i was at my local 1/8th mile track and made a few runs so first run i dident heat em up and the car did spin then hooked then on the second run i heated um up real good and the car dident even chirp the tires.
im makeing around 340hp at the wheels.
Mid 1.9s since I put the 3.42s in, a little bit of spin every time since then (this should not happen). I run them at 25 psi and burn them for 5 seconds after I start to see smoke. Maybe I need to burn them longer. Or maybe they're too old and are starting to harden a bit; I got them used 3 years ago, not sure how old they actually are.
