Flush the Front Wheels! anyone do it?
Old Jul 17, 2010 | 09:54 PM
Eskimo's Avatar
I've got my 9.5" wheels at 36mm right now (standard 56mm wheel with a 20mm spacer/adapter) and it sits perfectly, and only barely rubs the little nub just inside the fender (run your hand along the inner fender liner, near the 12:00 position there's a part that sticks out) when I really crank into a corner..
-1.5° camber, 265/35-18 Michelin PS2's
IMO, a 275 tire on a 9.5" and a 315 on an 11" typically seem to look "right", though the Michelin's look wider than spec probably because of the rim protector.
I will try to take some photos tomorrow.
Old Jul 18, 2010 | 04:59 PM
Xsta Z 28's Avatar
Exclamation
Originally Posted by 99Bluz28
So what's the camber set at, 0, +.5 ?
Definitely no negative camber here.
OEM specs . . . as far as I know . . .
Old Jul 18, 2010 | 06:17 PM
BOBS99SS's Avatar
Captain Double Post
I was wondering about this 2. 17x11 on the rear look great I always thought 17x11 on the front if they didn't stick out to far would look nice.probley get a hate comment for that.I saw a 03 cobra the other day runnning 18x10s on all 4 corners and it looked sweet I know on those cars you can run a widder wheel on front but looked real mean. Could you use a spacer to push the wheels in the front out more
Old Jul 18, 2010 | 07:53 PM
Eskimo's Avatar
The first picture is the wheels at 70mm rear (11" wide wheel, 305/30-19 Michelin PS2) and 56mm front (9.5" wide wheel, 265/35-18 Michelin PS2). Second picture is with 20mm spacers all around, bringing it to 50mm rear and 36mm front.
With spacers:
Shot to show the front wheel/wheel well relationship better at 36mm:
HTH..
Old Jul 21, 2010 | 09:16 PM
LS1TORQ's Avatar
Great thread the OP started. ESKIMO, your offsets look real good and so do those rims!!
ESKIMO I'm sending you a pm with an off topic question
Old Jul 22, 2010 | 09:35 AM
gyrene2003's Avatar
where can u get the spacers at?
Old Jul 22, 2010 | 10:21 AM
Eskimo's Avatar
The H&R ones are part number 4085704. Search away!
motorsport-tech dot com does the custom ones.
Old Jul 22, 2010 | 06:57 PM
00SS4780's Avatar
I'm sure some will not like or agree, but I have a 1" adapter on mine. It sits the tire flush with the top of the fender. I love it like this. Not sure, but the camber n stuff is within specs. Here are some pics:
Old Jul 22, 2010 | 07:10 PM
gyrene2003's Avatar
these cars should of come like this from the factory, looks so much better.
Old Jul 22, 2010 | 07:17 PM
scj's Avatar
scj
is that a 9.5" wheel in the front?
Old Jul 22, 2010 | 07:36 PM
LS1TORQ's Avatar
GREAT setup! Could you post some non-close up pics so we can see what the whole package looks like?
Old Jul 22, 2010 | 08:07 PM
  #32
meine96ws6's Avatar
Nice...
Old Jul 22, 2010 | 11:43 PM
  #33
00SS4780's Avatar
Yes. It is the stock front wheel. Ill post some better pics when the weather clears up.
Old Jul 24, 2010 | 09:59 AM
  #34
gyrene2003's Avatar
which sponsor actually sells these for our cars
Old Jul 24, 2010 | 05:18 PM
  #35
00SS4780's Avatar
Not sure. K just googled it and found the cheapest billet one's. Here are a few more pics:
Old Jul 24, 2010 | 06:23 PM
  #36
99wssixm6's Avatar
Any sponsors?
Old Aug 3, 2010 | 02:08 PM
  #37
01Blk*SS*'s Avatar
i bought some custom made wheel adapters from motor sport tech.
try googling it.
Old Aug 4, 2010 | 02:48 PM
  #38
joblo1978's Avatar
I run 1/2 spacer in the front and 5/8 in the rear on my 56mm offsets. ARP extended studs of course. Baer billet aluminum lugcentric spacers.
Took me some experimentation to get the looks I wanted. I could slam the car more if needed, but the coilovers are set more for drag right now.
Looks good and is almost flush.
If you go out too far, you can slash your tires with the fenders if they're not rolled and your slammed. You will also scatter alot of rocks down the sides of your car.
My WS6 wheels were basically flush with these spacers, but I sold those.
Old Aug 4, 2010 | 06:38 PM
  #39
LS1TORQ's Avatar
Nice pic!!!!! ^^^^^^^
Old Aug 4, 2010 | 11:45 PM
  #40
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Yeah, I agree. I have OEM C5 wheels on my 95 and the rears are tucked way too much. I need to bring them out some for better clearance and looks.
