Pics of GTO spares/skinnies on fbodys wanted
Just as the title says. I'm wanting to know what they look like on an Fbody. I can pick up a pair from a guy locally for $50. Thought i'd run them as skinnies but i was curious what they would look like. I know they sit more inside the wheel well and i was hoping for pics with some spacers used also. Thanks!
Awww man! I had this exact setup for tonight but it rained so I never threw them on! Awesome, maybe in a few weeks. but I don't think you should run on the spare tire, the rims would be okay i'd think
Just as the title says. I'm wanting to know what they look like on an Fbody. I can pick up a pair from a guy locally for $50. Thought i'd run them as skinnies but i was curious what they would look like. I know they sit more inside the wheel and i was hoping for pics with some spacers used as well. Thanks!
Be careful.
Good luck!
This is not for argument sake, if you feel comfortable with what you’re doing, so be it. At least for the others reading and learning…they understand what they are getting into. I know I won’t race next to a car that is setup as such. I’m not even sure if the track would approve as it’s probably stamped for low speeds.
It doesn't matter who runs them and how many run them. It's the incorrect pattern of which you remove even distribution of pressure on the studs. This increases the chance of a stud failing as well as increasing the chance of the lugs loosening thus possibly creating a driving hazard.
Furthermore, the wheel is designed to be used as a spare for low speeds and low duration of use. I don’t know what the weight of the wheel is offhand, but if it’s steel, you’re not really gaining anything from a rotational standpoint. The idea of a drag wheel is to remove rotational weight, not to just be a skinny wheel that looks like a drag wheel.
Hope this helps,
Steve
Mechanical Engineer
SJM Manufacturing Inc. & Bogart Racing Wheels
Hope this helps,
Steve
Mechanical Engineer
Hope this helps,
Steve
Mechanical Engineer
Hope this helps,
Steve
Mechanical Engineer
Sounds like you don't care about the performance bit, if theres even ANY positive side to it.
It will look like you're running on spares, you won't fool anyone.
Use your street tires.
Even if you get the wheels you're going to have to spend 320 bucks on proper tires as GTO spare tires have a max speed rating of 55mph, so by that time you might as well spend another 100 bucks and pick up a used set of Welds to put the tires on.
So, instead of not doing something the right way because you can't afford to, you'd just rather half *** it and put your own life, as well as the guy racing next to you's life at risk because you didn't want to spend more than 50 bucks? Please do us all a favor and stay away from the track, or keep your stock wheels on, tight.
a camaro and vette have a standard bolt patern. a gto has a metric patern. the wheels with interchange though because of the difference being less than a few millimeters. i have ran f body snowflakes on my gto and they bolt up fine and yes safely. all kinds of people are using just the gto spare wheel with a street tire on it for skinnes. its not unsafe. just a cheap way of getting it done.
man you drew out the panzies on this one lol.
I just asked for some pictures!
If you want to talk about safety, many people run VW tires on their skinnies... They're only rated to 80mph, but people go 8s on 'em.
The guy wants to know if anyone has done this, not if you deem it safe or not. So, I would say, butt out of the thread unless you've got something constructive.
I sir, am not a Hillbilly. My **** is set up properly. But if other people want to other ****, I don't really care. That's the problem with Tech. Everyone is so sensitive and gets their little feelers hurt. Not calling you out individually Camaro396, just ranting in general since this thread already got **** on.
