lightest drag skinnies ???
I write checks with my mouth that my ass can't cash
just thinkin into the future i want to purchase atleast the front two skinnies and i was wondering the weight difference in some of them, bogart d-10, weld draglites, prostars ect....or what is the lightest ? iv heard of people gettin 2 tenths out of skinnies that seems a little much but it may be possible considering i weighed one of my front wheel/tires and it was 50lbs on the dot...
Location: Your girl's back door giving her the long stroke while you're at work
Either Bogarts or the NEW Weld Magnums are probably the lightest. If you run a radial tire on them then they will be heavier
depending on how we need to manufacture our Bogarts, price and weight will vary. We can build them as low as ~6.75lbs per wheel. I can build them to directly fit your oem brakes calipers and rotors.
If we are building them for drag brakes, they will be least expensive. Starting pricing is 265 per wheel for a drag wheel.
