All with 18s out back...Help me out
Just wondering what size tire you are using....I am hoping to go with something along the lines of 18x10.5 with a 295-35-18 Eagle F1 Supercar??
Anyone running this setup on an F-bod? Will it clear?
Anyone know of wheels in this size? I am hoping BC offers this size....I like the Timeless 2s.
TIA,
-Nick
TIA,
-Nick
12 Second Truck Club
i have that same set up on my car with oem z06's. i had to run a 1/4in spacer, grind down the bump stop a little to keep it from hitting the inside of the wheel on big bumps, and massage a small part of the wheel well to keep it from rubbing on hard cornering. have fun, hope this helps.
Originally Posted by Red02Firehawk
Wouldn't a slightly larger bump stop HELP the situation?
I too want to see people chime in on this one. I am doing the same.
I was wondering the same? A bigger bumpstop should eliminate the possibility of hitting the rear Quarter...
From the sound of it the 295-35-18 will work great as long as you have a wheel with the proper backspacing/offset... With stock Z06 rear wheels however, you need a spacer and may need to roll the rear fenders. (From what I have read so far..)
I am also going this route with the zo6 wheels and have been told that if you get 56 or 58mm offsets the 10.5 will fit with a 295 series tire. But I want a few more opinions on the situation. I really dont want to have to touch my fender, but am willing to negotiate with the wheel-well a little.
With reproduction zo6 wheels what kind of offset should we all try and get?
Thanks
Fry
Thanks
Fry
its all about the offsets. if you put 18x10.5 on the rear with a stock z06 wheel you will rub like hell. But if you get a 50 mm offset you will be set. I have made my plan to get 18x9.5 w/53mm offset and 18x10.5 w/50mm offset. From what I have been told with 275/35 front, and 295/35 rear and these rims everything will fit perfectly except maybe a small rub but nothing major.
Fry
Fry
