Will the 17x11 ZR1's stick out?
And are these the correct specs for my 98 SS?
17" ZR-1 SILVER CORVETTE REPLICA WHEEL
ORIGINAL CORVETTE CENTER LOGOS
FRONT WHEEL SIZE ( 17 X 9 1/2" ) 56mm OFFSET
REAR WHEEL SIZE ( 17 X 11" ) 50mm OFFSET
BOLT PATTERN ( 5 lug, 4 3/4 )
From this auction: http://cgi.ebay.com/ebaymotors/ws/eB...tem=2456320921
I plan to mount 315 BFG Drag Radials out back.
Those are the specs you want. They wont stick out with the 50 mm. Wont rub either, even if you are lowered. If you get the 36 or 38 mm rear offset they will be out about an inch.
