Drag setup?
Old Jan 22, 2011 | 09:44 PM
1998MysticZ28's Avatar
Default Drag setup?
Hey guys I might be in the market for a drag set up. My car has h/c and all the fun stuff. But Im still on a street radial. I was dumb enough not getting and 11" rear when I bought my Zr1's. Now my I need a Drag radial for when I go to the track, but dont know what I should do. I still have the stock 5 star z28 rims 16x8 should I put a radial on that? Or should I get a skinny front tire and something wide out back. My buddy has a set of pro stars but I really dont want to grind the calipers. I know only one or two companys make wheels that fit over the stock calipers on a 15" rim. What do you guys suggest....
Old Jan 22, 2011 | 10:43 PM
Wow, just re-read that and it doesnt sound right at all. Basically would the stock 16x8 with a drag radial be good for my setup. or should I step up to a real drag set up?
Old Jan 23, 2011 | 01:50 AM
Cayenne's Avatar
Mickey Thompson makes a 255 drag radial for a 16" wheel I think.
Old Jan 23, 2011 | 01:58 AM
think47's Avatar
You can run the 245/50/16 nitto 555r's on them,as far as grinding the calipers for skinnies, I believe all you need is a 5/16 spacer up front and you're set, only reason I know is because i have 15 x 10 out the rear and about to buy my skinnies for the front, except I am running a 15 x 6 because i daily on them
Old Jan 23, 2011 | 02:26 AM
lemons12's Avatar
If your track even half *** preps the track you should be good with a mt radial on the stock rim. I would probabpy go et street though, the onebwih the two thin lines..
Old Jan 23, 2011 | 02:41 AM
01ssreda4's Avatar
Yeah if you pick the non-radial ET Street on the stock 16 inch rims, it should hook like a MF.
Old Jan 23, 2011 | 08:35 AM
Still working on the stock rear end so have to keep that in mind. lol
Old Jan 23, 2011 | 08:43 AM
lemons12's Avatar
If a slick will kill it a radial or cheaper slick will as well.
The stickier the tire, the more consistent.
Old Jan 23, 2011 | 08:49 AM
well I knew that, guess Im just gonna be a little easier coming out the hole
Old Jan 23, 2011 | 08:53 AM
3rdgen92maro's Avatar
Et streets on the stock 16x8s or the 255 radials. Is your car a a4 or 6spd?
Old Jan 23, 2011 | 09:03 AM
lemons12's Avatar
Are u an m6?
Old Jan 23, 2011 | 09:10 AM
a4 with 3600 stall speed, built tranny and 3.73 gears on a stock rear end
Old Jan 23, 2011 | 09:38 AM
lemons12's Avatar
You should be good for a while unless it is already hurting.
Old Jan 23, 2011 | 10:05 AM
Cape T/A's Avatar
Put the 255/50/16 ET street radials on there and you'll be alright
Old Jan 23, 2011 | 10:45 AM
thanks guys
