Weld Drag Wheels Now Available & In Stock @ Texas Speed!
Well, it all depends on design. The centers are much larger and I'm assuming it's designed different, this is where a higher percentage of added weight will be.
Its not marketed as a drag wheel, its a street wheel from what I understand. So the weights indicated could be realistic depending on shell thickness as well as increased center section mass. As you know, a drag wheel is not a street wheel where there are completely different benefits for both designs.
I am interested in compare and contrasts between these and other wheels. I'm not going to discuss them in here as this is not the place for it. I'm interested in understanding what the facts are about these wheels.
Maybe wheelczar can comment and clear up a few questions. I'd like to hear the official weight of the fronts and rears. The shells, what material hardness are the shells manufactured with...cold formed and are they solution hardened or final machine temper left after forming? If hardened, to what grade?
Thanks,
Steve
Thanks,
Steve
LS1Tech Premium Sponsor
Shoot me a PM with which style, color, and size you're looking for and I will get you all quotes!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
They offer quite a few for the C6 as well! Shoot me a PM with roughly what sizes you want, and I can send you the list of wheels they have in that area and see what you want!
__________________
#33
Back at ya!
__________________
