What Tire Size To Go With
Old Feb 13, 2011 | 09:06 PM
C0wb0y's Avatar
Default What Tire Size To Go With
I ordered some 15 X 10 Rims for the Rear and some 15 X 4 rims for the fronts but whats the best size tires to put on them and the best brand? Im wanting DOT Drag radials cause the car will see a little bit of the street. Any Info will be great... Thanks
Old Feb 13, 2011 | 09:50 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Mickey Thompson for both front and rear, Sportsman #1573 fronts and the rear depends on the car setup if you need a 26" or 28" tall tire
Old Feb 13, 2011 | 10:08 PM
C0wb0y's Avatar
what all info do you need?
Old Feb 13, 2011 | 10:42 PM
C0wb0y's Avatar
Also im wainting to be tubeless
Old Feb 14, 2011 | 10:06 AM
LS1RedZ's Avatar
Whats the setup on your car? Power?
Old Feb 14, 2011 | 10:48 AM
C0wb0y's Avatar
My car is a 97 camaro has a BBC 454, th400 trans with 4.11 gears Im guessing it will produce about 750 rwhp
Old Feb 14, 2011 | 07:30 PM
C0wb0y's Avatar
Could really use some help as I'm wanting to order these soon
Old Feb 15, 2011 | 02:18 AM
C0wb0y's Avatar
Ok did a little reserch and the Mickey Thompson ET Street Radial Tire seems to be #1. But should i go with P295/55R15 (28'' x 12.5'' - 15'')
or P325/50R15(28'' x 13.5'' - 15'')? Please help
Old Feb 15, 2011 | 07:28 PM
C0wb0y's Avatar
Well since noboy will give me any help i guess i will just order the P295/55R15 (28'' x 12.5'' - 15'') and hope they are the correct ones
Old Feb 16, 2011 | 10:39 AM
LS1RedZ's Avatar
Get the 325/50 ET Radials!
