question about backs spacing and offset. specs inside! help please!
will these specs work??
(rears)
Specifications
Wheel Size 18x10.5
Color Chromium Black
Bolt Pattern 5-114.3/5-120
Offset +20
Backspacing 6.54
Lip Depth 4.25"
Centerbore 73.1
TPMS Compatible Yes
Approx. Weight 24.8
JWL/VIA Certified Yes
(fronts)
Specifications
Wheel Size 18x9
Offset +35
Backspacing 6.38
Lip Depth 2.75"
Centerbore 73.1
TPMS Compatible Yes
Approx. Weight 23.7
(rears)
Specifications
Wheel Size 18x10.5
Offset +20
Backspacing 6.54
Lip Depth 4.25"
Centerbore 73.1
TPMS Compatible Yes
Approx. Weight 24.8
(fronts)
Specifications
Wheel Size 18x9
Offset +35
Backspacing 6.38
Lip Depth 2.75"
Centerbore 73.1
TPMS Compatible Yes
Approx. Weight 23.7
Anyone? Because the edge its self is an 1 inch and if the difference is only 18mm which is less than an inch.. so if I rolled the fender wouldn't it make up for the difference?
