17x11 for whats its worth (new tire PICS) End
Old 05-05-2011, 04:48 PM
VinR1's Avatar
Originally Posted by scj
please tell me that's your ride height? **** yes.
LMAO thats sig worthy right there
...as I patiently wait for my 2" Intrax springs to arrive
Old 05-05-2011, 06:40 PM
BRD-PREY's Avatar
I'll measure it this weekend as I 've done a lot of messing around. It should be 6.75" front and 7" back. these measurements are from the front rear lower control arm bolt to the ground and from the front lower control forward bolt to the ground.
Old 05-06-2011, 03:08 AM
Turnin20s's Avatar
Damn that car looks good, and making it lower it will look even better
Do you have any pics of you modified factory bumpstops??
Old 05-06-2011, 06:29 AM
BRD-PREY's Avatar
Default Look back at the pictures
I didn't modify the factory bumpstop ( it was cut shorter) I removed it and cut the mount off. I built custom ones inside the adjustable spring perches. There is a write up post now in the suspension section where I posted the parts needed to make the perch.
Old 05-06-2011, 01:54 PM
Turnin20s's Avatar
I know you aren't using the factory stops anymore. I was just curious how you cut them to get them flat like they are. I cut the bottom off of mine and have been trying to figure out how to get them flatter like yours are
Old 05-06-2011, 11:12 PM
BRD-PREY's Avatar
I came from the top with a 4.5 " grinder with a cutoff wheel I cut down and in on an angle.
Old 05-07-2011, 08:21 AM
lees02WS6's Avatar
I like the bump stop location, you could also have run a koni bump stop over the shock shaft.
Old 05-07-2011, 08:50 AM
Camaroking1996's Avatar
That Bird is Saying "Don't Mess With Me I WILL EAT YOU!"
Old 05-07-2011, 09:51 AM
whytryz28's Avatar
Its 100% totally possible to tuck 17x11" wheels under stock fender wells. I hate when I see people with 315's+ that stick out past fender well, looks redneck as hell.
Lowered almost 2.75" rear, stock bump stop, BFH some parts of the inner well, rolled lips, spent awhile adjusting my PHB also. Might be able to squeeze a 335 under too from what I can see.
Quick Reply: 17x11 for whats its worth (new tire PICS) End
