Race Star "F body specific" wheels........
Old May 27, 2011 | 12:43 PM
jt76's Avatar
Default Race Star "F body specific" wheels........
So much for being F body specific... i put them on and they are grinding on the rear calipers (i have yet to try the fronts, no tires yet) Has anyone else experienced a similar issue? Time to get the grinder out
Anyway, they do look badass
Old May 27, 2011 | 12:56 PM
JohnnyBz28's Avatar
I had to lightly grind them on the rears but not the fronts.
Old May 27, 2011 | 01:14 PM
bpittman's Avatar
What size Hoosiers are you two running? Both look awesome. Any inner/outer fender modifications required?
Old May 27, 2011 | 01:30 PM
JohnnyBz28's Avatar
27x11.5x15 rears
I need to roll my rear fenders I think but as of right now I haven't had any issues.
Old May 27, 2011 | 02:17 PM
z28adiction's Avatar
mine are 17X11.5 as well -JT76
Old May 27, 2011 | 04:52 PM
studderin's Avatar
that sucks, you must have some thick brake pads back there.
What tires did you get for the front? I need to get some street skinnies. \you got the rims 15x3.5 15x10?
you have lugnuts and wheel studs yet? Im gona be selling my ARP 12mm studs, and lug nuts for thouse wheels. I went to bigger studs.
Old May 27, 2011 | 05:26 PM
JohnnyBz28's Avatar
I have Hoosier 26x4.5x15 tires for my fronts
Old May 27, 2011 | 08:51 PM
jt76's Avatar
Yeah, the rims are 15X2.5 and 15X10.. I already have front studs and McGard lugnuts, i was running weld drag lights a few years back, i still need to pick up tires for the front.
Old May 27, 2011 | 09:32 PM
jt76's Avatar
After an hour of "strategic weight removal" the wheels finally fit. I love the way these look, just make sure you or someone you know has a trusty dewalt angle grinder
Old May 27, 2011 | 09:37 PM
JohnnyBz28's Avatar
What part of the caliper did they hit? I only had a slight rubbing issue which 5-10 minutes of grinding per side solved.
Old May 27, 2011 | 09:55 PM
jt76's Avatar
It was hitting ever so slightly on the front top of the caliper itself and hitting pretty good on the 3 "ribs" on the back.
Old May 28, 2011 | 03:15 PM
studderin's Avatar
Nankang CX668 Tire/s 165/80-15
http://cgi.ebay.com/ebaymotors/ws/eB...51846029380322
Old May 28, 2011 | 03:46 PM
JohnnyBz28's Avatar
That's where mine was tapping but it only took me and a friend 5-10 minutes max lol
Old May 29, 2011 | 08:35 AM
Camaro396's Avatar
Says they are rated to 112mph
Old May 29, 2011 | 11:10 AM
IWGF's Avatar
Yes, on the Racestars you have to grind the cooling veins on the backside of the caliper. I get at least 1 PM a week asking about them lol.
Old May 30, 2011 | 05:21 AM
Nitroused383's Avatar
My racestars spun freely but you could hear it slightly rub in 1 spot. I just hit the high spots of the calibers, took no time at all.
Old May 30, 2011 | 04:46 PM
jostang50's Avatar
mine cleared no problem. 15x10 7.5 bs with 275-50-15 and the fronts also.
Old May 30, 2011 | 11:08 PM
IWGF's Avatar
Are your brake pads low?
Old May 31, 2011 | 02:28 PM
nx346's Avatar
That's the tire I ended up putting on my RTS wheels. I daily drive the car and, so far, so good. Of the cheaper frontrunners I have looked at, these seem to be better quality as compared to some others. Still probably not as good as an M/T, though.
Old May 31, 2011 | 05:49 PM
jostang50's Avatar
here are some picture of mine to show how much room i have to the calipers. hope this pictures show.
rear
fronts
I think i have about 3/4 inch away from the calipers. Part number i have for Racestar rears are 92-510354p and i'm using a Greg welds up front for Fbody 15x3.5 1.75 bs
