315/40/18 Nitto NT05R question
So I'm looking into getting new wheels and like these tires but need to know if it's going to mess with my ABS (not 100% on it). The front tires will be 275/40/17's
That is a wider and taller wheel. when you go wider, with the same second number, it gets taller.
That rear tire will be 2.26" taller. Ive been told we are only allowed one inch difference. my abs does not work and it sucks
here is a tire calculator. you can get a ruff idea here. The actual tire size may differ. You should always check the tire company afterwards
http://www.discounttire.com/dtcs/infoTireMath.dos
Damn I have no idea what to do now. I will be definitely running my 275/40/17's out front and I want a 315 out back (obviously for looks). I live in NYC so potholes are everywhere so I wanted something with a decent amount of sidewall like my front tires.
Cheapest I found so far was $612 shipped for 2 BFG drag radials 315/30/18's
Just an example:
275/45/17 is 26.74"
215/40/18 is 24.77"
315/40/18 is 27.92"
The first number is always relevant. Actual sizes should be checked with the tire manufacture
Tried to find a friend with a 275/45/17 up front and see if the ABS works. That with the 315/40/18 will look great IMO.
Just some ideas. Post up what ever you do and goodluck
here are some pics of mine. I like the stance. Im goin with a taller tire up front next time. I think I have 255/45/17. i have a set of 275/40's that are goin on. The rear tires are 295/45/18
I've seen the 275/40/17 and 315/30/18 combo. Doesn't look too horrible. I would just stick with the 315/40/18 but the car is daily driven in NYC so I'd rather not disable ABS lol. Too many idiots out there.
Sidewall on a 275/40/17 is 4.3
Sidewall on a 315/30/17 is 3.7
Sidewall on a 315/40/18 is 5.0
