1" wheels spacer on trans am
#44
got a problem?!!
here's what i got and trying to put on today....
and my problem is the OEM studs stick out a little to far and when i try to put my wheel back on ....it wont go cause it hits the studs. (yes i know im suppose to put the nuts on the spacer before the wheel goes on)
looking a the OEM 01 Speedline back...i figured the OEM studs would just sit right in the extra cavities but its a no go...they just hit and wont allow the wheel to go on.
DO i cut what is extending past the 1" spacer? I mean i know i can but will it screw up the hub if and when i go to another wheel?
#46
yeah cutting will be alot easier which is what im gonna do....
yeah but if i ever wanna go back to not using the spacer....will i have to replace my wheel studs to be able to use a different wheel?
im thinking it will be ok...I only have to cut right down to the threads and not past. Its just good to have that extra bit of stud.
#48
got a problem?!!
http://i147.photobucket.com/albums/r...8/IMG_1014.jpg
http://i147.photobucket.com/albums/r...8/IMG_1022.jpg
http://i147.photobucket.com/albums/r...8/IMG_1021.jpg
#49
ummm....your a little late with the reply.....the pictures above are after. Yeah i used a cut off wheel on a grinder and did put a nut on before cutting off the nub, I had to go 1 thread farther so all is good!
I think 30mm would have stuck out a little to much for my liking I good with the way it looks with the 25mm.
#50
do they come single? or in pairs
#53
LOL....yeah i know there is no camber/toe adjustment for the rears. They attached those things to all 4 tires for a reason....to see if the front to rear are aligned or your car is side step-in cause when i adjusted my PHB i had them check it on the machine to see how close i was.
#55
Everyones cars is looking great!!!!
I ordered a set of H&r for my friend. The h&R fit a little snugger on the hub than mine did, but mine were off brand.
Go for h&r guys. both mine and his both I tightend them with a 4 way and they never have broke loose, but still worth checking after a couple miles.
#58
I was just going to use some 5/16 spacers I have around with longer studs but after seeing those pics I think I'll go with the 20mm adapters. Maybe I'll just use the 5/16 spacers up front and the 20mm on the back.
#59
I've got a 2000 WS6, can I get 315s on the rim? It looks like many of you have the stock rim with 315s and a spacer.
Also what does it mean to have a rolled fender?
Mine is dropped about 1.8 inch with QA1s.
thanks for the help.
Newbie
Newbie
#60
no you cant put 315's on the stock WS6 rim....and no we dont have 315's on our stock rims
with the spacer it gives it the look of having wider tires because the spacer puts the wheel out further towards the edge of the rear quarter panel.
rolled fender means, using a tool or BFH and bending the underside of the edge flat against its self......best i can put it.
feel up under your rear edge and imagine it not there but being bent flat at a 90*
