17x11 rub
bend and break the chassis in half.
J/K, you don't really need them unless you planned on driving the car like the Duke Boys.
Get a watts link and proper bump stops.
Im running OE wheels ZR1s (17x11) with a watts link and Z28 bump stops, and no BFH'ing or cutting was required. I ended up doing a little hammering on the drivers side because I had very minor rubbing under hard turns (which leads me to think that the axle is not 100% centered - my own fault). Bump stops remain, just jack the car up by the axle if you don't want them to touch. No sense in destroying suspension geometry by doing something irreversible like cutting bumpstop mounts away to fit wheels. Get a proper fitting wheel and suspension setup and problem solved.
I fill my trunk every year for car shows and I am a big guy and I have NEVER hit.
Its all in the correct offset, consult the tire stickies, your not the first with this issue.
