17x11 rub
Old 01-10-2012 | 12:26 AM
  #41
whytryz28's Avatar
Fire chickens have wider fenders.
Old 01-10-2012 | 08:31 PM
  #42
unioncarpenter84's Avatar
Originally Posted by 99'CajunFirehawk157
17x11 ttii's w/315's, stock slp bump stops, NO bfh mods, NO cutting, stock springs.
I fill my trunk every year for car shows and I am a big guy and I have NEVER hit.
Its all in the correct offset, consult the tire stickies, your not the first with this issue.
whats the offset u got
Old 01-10-2012 | 10:14 PM
  #43
VinR1's Avatar
I believe Cajun's offset is 44mm...correct me if Im wrong
Mine are 36mm - still have bumpstops, no hammering whatsoever. At stock height, everything was fine but I rolled the fenders before lowering it 2" just to be safe. Agreed, its all in the offset
Old 01-11-2012 | 04:21 PM
  #44
would a 50 or 56 offset be good is tht further out or futher in
Old 01-11-2012 | 05:51 PM
  #45
VinR1's Avatar
It would set in towards the car further. You see guys with 50mm and 56mm offset wheels needing to hammer the fender wells... on the flip side, my ZR1s are 36mm so they set almost a half inch further out. I didnt need to hammer anything but I did roll my fender lips...
Old 01-11-2012 | 06:32 PM
  #46
u got a side pic of the fendersbeing rolled
Old 01-11-2012 | 08:21 PM
  #47
Fast T's Avatar
Originally Posted by jblack245
Does anyone else 17x11 rub when you get into a turn? Mine do. In the rear. Its not lowered. Is that normal?
Mine dont rub and its not lowered but i have heard of it happing.
Old 01-11-2012 | 08:32 PM
  #48
those the wheels from oe wheels
Old 01-12-2012 | 06:55 PM
  #49
JD_AMG's Avatar
Originally Posted by kyoytey1693
Do you have some side or rear shots of your car with those wheels? I'd like to see a better shot of how they look. I seriously considered some of those before I had my speedlines widened.
Yep, I love the way these fit, flush to the fenders and gives a killer looking stance. I considered widening my speedlines too but decided against it because its would be a pain IMO (gotta leave car on jack stands for a while, and then Id be afraid if it wasn't a quality job and the wheels end up cracking or breaking) and these are so inexpensive.
https://ls1tech.com/forums/14994698-post1768.html
Old 01-13-2012 | 03:19 AM
  #50
TruBloodTransAm's Avatar
JD_AMG, what tires are those?
Old 01-14-2012 | 11:36 AM
  #51
JD_AMG's Avatar
Nitto NT05 (not the NT05R, just the regular ones).
